Volvo 240 small tachometer (52mm) which goes in one of the blank spaces to the right of the instrument cluster. Included are 3 rubber holders and a plastic bezel. It's a 4-cylinder tach with a 6500rpm redline, from an early '80s 240 w/B21F engine (it will work with any 4cyl). Asking $30 plus shipping for this rare accesory gauge.<P>Installation is simple. Run one wire from "+" to a power source switched on at position II, and run one wire from "T" to a ground connection. Then find the pre-existing red/white wire with a spade connector that's behind the instrument cluster, and attach it to "G" on the gauge. It probably won't be long enough to reach to the gauge, so I'll include a wire with connectors on either end that will allow you to reach the red/white wire.<p>[This message has been edited by towerymt (edited 09-27-2001).]
