1 - 8 of 8 Posts
Had a phone call from Volvo Canada today telling me not to use the Preconditioning or Remote Start from the VOC app. There is a bug that may cause the engine check light to come on after using these functions. They are working on a solution. Estimated delivery date of fix sometime in Q2 or Q3. Yep I questioned that as well. When I asked why it would take so long, they couldn't give me an answer. It was pointed out that I could still use the preconditioning timers from the car screen.
Must be some kind of super bug to take so long to fix.
Has anybody else been told this?
I use both functions quite often and only once got the check engine light which I think was related to the very cold temperatures. The light came on after stopping and starting the engine with the knob not the APP. It cleared after a two days.
Yep, that is also a reason cause CEL on my T8. If I remember correctly, it did happen on your T8 as well.
FYI, if you stop using precondition or remote start, the CEL will clear itself. I did test it on mine :)
It's not a long time, it's super fast for Volvo developers. :)
There problem with sudden acceleration more than a year and Volvo has still not solved the problem :confused:
The answer is still always: the software is in the test phase ( :mad:
I have a 2019 T6 inscription I just bought in Nov 2018. I have been using the remote start with the preconditioning (i.e. turn on heated steering wheel and heated seats) since I got it and not had any issues with it? Does this only affect specific models?
You should be fine. This issue is for 2019 T8 only
1 - 8 of 8 Posts
