eBay is the place. Now, which vender is the question as they seem to change all the time. Someone posted about buying one not too long ago. Hopefully they will chime in here.
Use VADIS, make sure you have IE9 uninstalled and IE8 running. VADIS works well too.
If you go with VIDA make sure you pay attention to which version works with your system. I finally ended up with VIDA 2012A on mine with Win7 Pro 64 bit. Older versions require 32 bit. 2012B has a different method of patching which I couldnt get to work.
