1 - 6 of 6 Posts
I got past the software install.. wasn't easy..
but having DICE problems...
DICE Unit connects to PC and also connects to the Car..
But VIDA has a communication problem when i try to read the car..
when i use the DICE Diagnostic application.. the Dice passes the LED test and the communication test, but fails the memory test.. it specifically fails the external flash memory test..
I have no idea what the problem is... any help would be cool....
All clones fail memory test. They don't have memory card slot for Flight Recorder application. It's irrelevant.
Your problem is elsewhere...
tried it again today..
didn't work at first.. but then just started working...
was able to clear SRS and do SUM calibration...
maybe it has to do with the sequence of how you connect the device...
who knows but ti worked...
definitely not plug and play....
Sometimes clones get locked out or smth. You nust make sure that firmware led is blinking green and usb blinks a couple of times when connecting with pc
When you connect to car. try run "communication test" on VIDA. if it OK. then DICE will working.
I hear some clone DICE may/may not full function - its may have some "un function" of VIDA.
1 - 6 of 6 Posts
