1 - 2 of 2 Posts
I have been inching towards getting this to work but I'm finally just stuck and am requesting some help. Everything works up until I attempt to access the diagnostics tab which is when the system returns the information below. Comm test passes.
My DICE Device: 206751
Hardware version: 1.4.3
Firmware: 5.6.2
Bootloader: 5.0
System.IO.FileNotFoundException: Could not load file or assembly 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
File name: 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at Vcc.Vida.DiagSwdl.Workflow.IdentifyVehicle.IdentifyVehicleWF.PerformIdentification()
at Vcc.Vida.DiagSwdl.UI.Diagnostics.ScriptExecutorUC.startIdentifyVehicleWF()
at Vcc.Vida.DiagSwdl.UI.Diagnostics.ScriptExecutorUC.ExecuteScriptByType(String scriptType)
at Vcc.Vida.DiagSwdl.UI.CommToolSetting.ReadVin()
at Vcc.Vida.DiagSwdl.UI.CommToolSetting.ReadVinButtonClick(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at Vcc.Vida.DiagSwdl.GuiComponents.FlatButton.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Loaded assemblies
System.EnterpriseServices, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
BizServices.AccessServer.DB, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
ResourceManager.resources, Version=2.0.5394.27529, Culture=en-GB, PublicKeyToken=null
VehCom2, Version=2.0.5394.27561, Culture=neutral, PublicKeyToken=null
ProgressHandler, Version=2.0.5394.27532, Culture=neutral, PublicKeyToken=null
BizServices.CarCom.DB, Version=2.0.5394.27553, Culture=neutral, PublicKeyToken=null
Util, Version=2.0.5394.27531, Culture=neutral, PublicKeyToken=null
System.Transactions, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
BizServices.VehicleResolver, Version=2.0.5394.27557, Culture=neutral, PublicKeyToken=null
Workflow, Version=2.0.5394.27569, Culture=neutral, PublicKeyToken=null
BizServices.SoftwareOrderRepository, Version=2.0.5394.27564, Culture=neutral, PublicKeyToken=null
BizServices.CarCom.VehicleServices, Version=2.0.5394.27554, Culture=neutral, PublicKeyToken=null
System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
BizServices.VehicleCommProvider, Version=2.0.5394.27562, Culture=neutral, PublicKeyToken=null
AppServices.VehicleAccess, Version=2.0.5394.27567, Culture=neutral, PublicKeyToken=null
BizServices.ScriptRepository, Version=2.0.5394.27556, Culture=neutral, PublicKeyToken=null
BizServices.DiagnosticSession, Version=2.0.5394.27554, Culture=neutral, PublicKeyToken=null
ValueObjects, Version=2.0.5394.27551, Culture=neutral, PublicKeyToken=null
ResourceManager.resources, Version=2.0.5394.27529, Culture=en-US, PublicKeyToken=null
ResourceManager, Version=2.0.5394.27529, Culture=neutral, PublicKeyToken=null
GuiComponents, Version=2.0.5394.27558, Culture=neutral, PublicKeyToken=null
AppServices.Scripting, Version=2.0.5394.27565, Culture=neutral, PublicKeyToken=null
AppServices.WorkshopSession, Version=2.0.5394.27559, Culture=neutral, PublicKeyToken=null
BizServices.InfoElementsRepository, Version=2.0.5394.27554, Culture=neutral, PublicKeyToken=null
System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
BizServices.SoftwareOrdering, Version=2.0.5394.27566, Culture=neutral, PublicKeyToken=null
AppServices.EcuDataResolver, Version=2.0.5394.27559, Culture=neutral, PublicKeyToken=null
Loaded databases
Discussion Starter · #2 ·
Finally got it working! Working so well I drained the car's battery. Looks pretty good so far although just a bit complicated to initialize compared to VCDS or Durametric for my other cars. For the cost of one service visit it will pay for itself.
1 - 2 of 2 Posts
