1941 - 1960 of 1984 Posts
Discussion Starter · #1,942 ·
run powershell as admin, paste the following and press enter. copy and paste the results...
Get-WindowsOptionalFeature -Online -FeatureName hyper
Discussion Starter · #1,944 ·
right click on powershell in the startmenu, then run as administrator
Discussion Starter · #1,945 ·
Product Rectangle Azure Operating system Font
Discussion Starter · #1,947 ·
When you paste it, you should get something like :
Code:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
PS C:\Windows\system32> Get-WindowsOptionalFeature -Online -FeatureName *hyper*
FeatureName      : HypervisorPlatform
DisplayName      : Windows Hypervisor Platform
Description      : Enables virtualization software to run on the Windows hypervisor
RestartRequired  : Possible
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-All
DisplayName      : Hyper-V
Description      : Provides services and management tools for creating and running virtual machines and their
                   resources.
State            : Disabled
CustomProperties :
DisplayName      : Hyper-V Platform
Description      : Provides the services that you can use to create and manage virtual machines and their resources.
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-Tools-All
DisplayName      : Hyper-V Management Tools
Description      : Includes GUI and command-line tools for managing Hyper-V.
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-Management-PowerShell
DisplayName      : Hyper-V Module for Windows PowerShell
Description      : Includes Windows PowerShell cmdlets for managing Hyper-V.
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-Hypervisor
DisplayName      : Hyper-V Hypervisor
Description      : Provides the Hyper-V Hypervisor.
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-Services
DisplayName      : Hyper-V Services
State            : Disabled
CustomProperties :
FeatureName      : Microsoft-Hyper-V-Management-Clients
DisplayName      : Hyper-V GUI Management Tools
Description      : Includes the Hyper-V Manager snap-in and Virtual Machine Connection tool.
State            : Disabled
CustomProperties :
Discussion Starter · #1,948 ·
Make sure you are doing this in PowerShell, not PowerShell ISE... Just like the picture I posted.
You can try downloading the new download utility, there are (3) download programs for each operating system, each downloading from a different datacenter. But if it says it downloaded, then it did. The download utility writes the file to the drive in realtime as it is downloaded. On Windows systems, it will download to the same location as the download utility unless YOU do not have permission to write to that location with the CURRENT authentication level. I.E., user account vs ELEVATED admin account. If you had filled out the form I linked to a few posts back, I would know what file you should be downloading and it would give me better ability to help you.
i downloaded it again under new setup under frankfot it went to 12 % and said some files missing and stopped
but santiago did work but same store like before downloaded file does not exist on my computer
now i deleted erupting and trying to download again but tis time i wrote my memory status and will se if memory goes down once it complied i already tried bunch times to donwload from santiago but keep getting error message and will not complete the download
still waiting on it for now it is much slower to download not than yesterday
there you go failed to download again went to 33 % and fails i tried all and same story
Discussion Starter · #1,950 · (Edited)
@goranvolvo
I'm sorry you are having issues but I'm certain the issue is either something to do with your computer, or your internet. Is it possible for you to try another computer or internet connection? As you can see, I just recorded myself downloading the same file you are using the same download utility and it works 100%... In-fact it only took 3 minutes. I also tested downloading from the Santiago location and it worked taking me about 10 minutes.
Ashburn Datacenter
Santiago Datacenter
Get-WindowsOptionalFeature : The requested operation requires elevation.
At line:1 char:2
  • Get-WindowsOptionalFeature -Online -FeatureName hyper
+ CategoryInfo : NotSpecified: :)) [Get-WindowsOptionalFeature], COMException
+ FullyQualifiedErrorId : Microsoft.Dism.Commands.GetWindowsOptionalFeatureCommand
Discussion Starter · #1,954 ·
That means you didn’t run as admin. Look at my post just a few up
oh my bad
PS C:\WINDOWS\system32> Get-WindowsOptionalFeature -Online -FeatureName hyper
State : Disabled
CustomProperties :
Discussion Starter · #1,956 · (Edited)
@FireFly666
You ran
Code:
it should be
Code:
You left off the astricts * at both ends
Discussion Starter · #1,957 ·
Sorry for the delay btw, I had wall switch explode last night in my house causing an outage. I'm currently replacing switches and outlets in the entire house. Builders didn't install things as they should have. Over stuffed gang boxes and stabbed wires with switches that were banned due to high risk of house fires. Thankfully yes I do electrical work too
Reactions: Capndirk
State : Disabled
CustomProperties :
