1 - 20 of 37 Posts
I was "cruising" at 245-250 kmh <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> on a german motorway (35deg C...+air con.) when I noticed that the revs were only at 5200 rpm. <br>I know it's a GT (my2006) but I thought that I would be closer to 6000... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>Any other experiences ?
Re: Very loooooooooong 6th gear (sR-71 Blackbird)
The '06 6GT top gear is 0.67:1, and it's fitted with a 3.33:1 final drive. The 6MT is 0.70:1 and 3.77:1. Effective drive ratios are therefore 2.231:1 auto and 2.639:1 manual, about 15% taller gearing for the auto.<p>Don't complain, you can maybe go faster. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>Tom.
which means that if you were able to hit redline, you would be doing about 326km/h or 196mph. WOW!
Re: (phuz)
Exactly <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>Gosh, so much to improve <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>BTW, very "quiet" ride at this speed. No hop, I was in "sport" mode, gear with "S" on.
Re: (sR-71 Blackbird)
The transmission is in lock up
Re: (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">The transmission is in lock up</TD></TR></TABLE><p>and this means....
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>and this means....</TD></TR></TABLE><p>Lock-up means the torque converter is locked, ie no slippage between the crank and transmission input shaft (mechanically coupled instead of fluid coupled).<p>LTA
Re: (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">The transmission is in lock up</TD></TR></TABLE><p>Of course it's in lock up, but the effective drive ratio is still 2.231:1.<p>What's your point? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <br>
and lockup is a bad thing?<p>pardon my ignorance when it comes to speaking in terms of automatics.
Re: (phuz)
No, lock-up is a good thing- just trying to figure out JRL's reference to lock-up and its application in this case.
gotcha<p>well i guess he was referring to the fact that there was NO slipping occuring and it was infact the true RPM for that speed. i dont know...hes being incognito today <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: (phuz)
In lock up your RPM's will be at their lowest
Re: (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">In lock up your RPM's will be at their lowest</TD></TR></TABLE><p>Duh...OK...So? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>
Re: (ljjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ljjones</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Duh...OK...So? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br></TD></TR></TABLE><p><B>I was "cruising" at 245-250 kmh on a german motorway (35deg C...+air con.) when I noticed that the revs were only at 5200 rpm. <br>I know it's a GT (my2006) but I thought that I would be closer to 6000... <br>Any other experiences ? </B><p>An explanation to his question
Re: (JRL)
<IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> ...I give up. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>
Re: (ljjones)
I would expect the GT transmission to be un lock-up immediately after it does a gear change. You don't drive a manual with the clutch half. The GT should lock up after every gear change.
Re: (BrunoS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>BrunoS</b> »</i></TD></TR><TR><TD CLASS="quote">I would expect the GT transmission to be un lock-up immediately after it does a gear change. You don't drive a manual with the clutch half. The GT should lock up after every gear change.</TD></TR></TABLE><p>But it does not. Most automatics do not. Especially the POS AW55 in the 04's and 05's. But it is much better than some of the other auto's I've (unfortunately) owned. <p>Most automatics have lock up torque converters, but many of them are reluctant to lock until pre-set things have happened, such as a minimum speed, a particular gear, and a certain time at cruise. <p>My old grand cherokee had only one critera for lock up - 50 mph. And you knew it locked. It was a very efficient transmission from that perspective. <p>The AW55 has funny times that it will lock and not lock. I dont' have enough seat time with it to fully describe it, but it's got some fuzzy logic, and must take into account more parameters than just speed. <p>
Re: (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">...The AW55 has funny times that it will lock and not lock...</TD></TR></TABLE><p>I'm not sure about the about the Volvo trannys specifically, but many autoboxes will lock the TC in a mid-high gear (4th or 5th for a 6-speed) and keep it locked through upward gear changes as long as road speed is maintained.<p>I'll bet the TC on the 5 and 6-speeds is ALWAYS locked up in the top gear above a certain (fairly low) road speed.<p>
Re: (ljjones)
Lock up IS there, just not as noticable in the Aisin Warner box (a good thing)<br>I was trying to explain to the person that kept rolling his eyes (with the "Duh, OK, so) is that when in lock up the transmission drops a few hundred rpms which is why he (the original poster) was noticing the lower rpms at speed,<br>that's all folks<br>
1 - 20 of 37 Posts
