They need to ditch the touchscreen tooLove those body panel lines! If Tesla could only do that!
Where is this be located? I may need some parts. Can you PM? ThxSo... A MY99 VR showed up at a nearby JY. It’s the first time in years of looking that I’ve seen one near me. Managed to get there early and pull some things. (I’ll be listing a few items for sale soon.) The spark plug cover was in better condition than mine, so I'll save that and the timing belt cover. On the Venetian, it started to turn pale blue and crack around the bolt heads due to heat. I know we discussed leaving them off so the coil packs don't cook, but is there any danger to leaving all three pieces off all the time? Will the heat from the engine without the TB cover bake the hoses to the power steering reservoir or anything else? Any real chance of something getting caught in the TB itself? I'm not planning on being the guy with the necktie caught in the shredder? If not, I think I'll leave everything off and save the new ones for Cars and Coffee or similar "show"-type use only. Thoughts?
As a safety precaution? To prevent cooking?leave the belt covers on.
to protect the timing belt. and you.As a safety precaution? To prevent cooking?
Snag list:So... A MY99 VR showed up at a nearby JY. It’s the first time in years of looking that I’ve seen one near me. Managed to get there early and pull some things. (I’ll be listing a few items for sale soon.) The spark plug cover was in better condition than mine, so I'll save that and the timing belt cover. On the Venetian, it started to turn pale blue and crack around the bolt heads due to heat. I know we discussed leaving it off so the coil packs don't cook, but is there any danger to leaving all three pieces off all the time? Will the heat from the engine without the TB cover bake the hoses to the power steering reservoir or anything else? Any real chance of something getting caught in the TB itself? I'm not planning on being the guy with the necktie caught in the shredder? If not, I think I'll leave everything off and save the new ones for Cars and Coffee or similar "show"-type use only. Thoughts?
Snag list:
18t
Greens
302mm front brake brackets
Amp and harness
Dash with dolby cover
Door sills
Wheel
Door cards
Cluster
99 R have 302s. Should be able to visually identity. That’s all a pretty standard price for a junkyard turbo, worth pulling if you’re ambitious....drop the front subframe bolts and the access will get very nice in a hurry.I already picked most of that.
I didn't think of the brackets. Did both MY99 and MY00 have them?
The turbo and injectors are less appealing based on this...
Part | Price | Core
Turbo Charger Pump / Supercharger | $75.99 | $10.00
Turbo Exhaust Pipe | $14.99 | $5.00
Turbo Intercooler | $49.99 | $10.00
Fuel Injector (each) | $11.99 | $1.00
Fuel Injector Rail (bare) | $15.99 | $2.00
LOL, I appreciate the checklist and the encouragement, but I'll probably won't go back at this point. Gotta leave something for everyone else.99 R have 302s. Should be able to visually identity. That’s all a pretty standard price for a junkyard turbo, worth pulling if you’re ambitious....drop the front subframe bolts and the access will get very nice in a hurry.
that's unamerican!!!!!!!!Gotta leave something for everyone else.
