Def not me lol I use only Mobil 3309 myself. Be my guest to use it thoIs anyone else running this in their transmission?
lol..Def not me lol I use only Mobil 3309 myself. Be my guest to use it tho
Also noticed this in the product specs
Volvo passenger car applications and STD 1273.41
I don't want my Volvo having any STDs![]()
Have you seen about a transmission software update?lol..
Actually I brought this topic up because my tranny kept shifting hard since I bought the car. Ive done 2 full flushes with the 3309/toyota fluid and one drain and fill mid last year... I was still getting a kick 1st to 2nd gear... and once in a while hard downshift.. Well late last year I said F it... I flushed my transmission with fluid with this stuff.. and threw in some Lucas Oil ATF Conditioner. My transmission didnt kick anymore. Well it's been about 10k miles and my transmission is still shifting very smooth. I just wanted to see if anyone else tried this fluid and what result they got... Not sure if it was the fluid alone or the conditioner... so far im happy with the results.
My car was at volvo for 3 weeks recently. I asked if there were any software updates on my car. I was told there wasn't. It might be a long time before I do another flush since this fluid is working so well.. I don't drive me R lightly... and so far this cheap fluid has held up well.. Ill see if its doing this well in another 10k.. That will be a good test IMO. I just had to find a better alternative for the toyota fluid. When I first used to get it it was 4.50 per quart a few years ago.. Now its like 9 bucks.. and I bought each gallon of the Maxlife for 16 bucks.Have you seen about a transmission software update?
I would try SeaFoam TransTune instead of Lucas next time you flush/fill/whatever. Also try Castrol Transmax Import Multi-Vehicle ATF which says its Toyota Type IV compatible also. I guess anything that says it's Toyota Type IV is ok to use, altho I'm no expert. I know the 3309 is not a Synthetic fluid
Sorry Mis-read your post, that's what I get for having a lunch beer (or 5)Since I've also been thinking about flushing the fluid I'll look into this fluid myself. Thanks
I was really hesitant at first.. but with my rough up and down shifts I was concerned that my tranny was on its way out or something.. I had to try something.. and luckily this one, IMO has worked for me so far. And I will continue to monitor and and update you all... so far the fluid looked good when I checked the dipstick last weekend.:thumbup:I use Valvoline, but their 3309 spec fluid. No issues with it.
There are (to my understanding) 3 or 4 things that play into which transmission fluid you want to use. Heat capability. Viscosity. Lubrication properties. Additives Package. If you use a fluid that is designed to run cooler, and put it in a high heat application, it will die quickly. This is part of what happened with Subaru and their automatics in the 90s. (and part of what drove the 3309 spec, imho) Viscosity plays a role in shifting. As I understand it, you put something in that is different, you may either slip a lot more (because it can't push the clutches correctly) or it will lock up tighter (because the trans can get more push out of the fluid) This is like dumping Dexron in old Fords made for F type (or was it the other way around??? too many years have gone by) One way you would shift much harder, the other it would slip like crazy. Pretty sure it was F type into Dexron that made them shift harder (Trick Shift, anyone?) Lubrication comes into play because if it doesn't lube properly, the metal parts eat each other up. Finally, the Additives pack, which includes detergents, friction modifiers, etc etc to make the stuff work better and last longer.
Personally, great that you experiment and found something that works for you... I wouldn't do it myself without seeing more evidence. No slight, just paranoid about breaking a transmission.
Too early to tell, but I will report back in a few more (thousand) miles. I'm optimistic but was very hesitant given all that I have read over the years, but Valvoline says its a replacement fluid so... Plus, since the trans has 138K on it now, I'm on a fairly regular drain and fill schedule (every 15K) so I'm not worried about fluid break down.So seangh, you're thinking this is better than the t-iv? I just ordered 12 qts of the t-iv but I'd like to know how this oil works out for you so next time I can get it.
I have exact same issue 1-2 gear, especially on downshift. Keep us posted.lol..
I only see the one MAX LIFE ATF on the Valvoline site, there is another non Max Life branded Multi Vehicle ATF that says for "Volvo passenger car applications"Valvoline does NOT say it is.
They have another Maxlife which is 3309 compliant which is now recommended by Volvo
Denis.. Car is still doing very well with this fluid. Still shifting very smooth.I have exact same issue 1-2 gear, especially on downshift. Keep us posted.
Actually, they do.Valvoline does NOT say it is.
Yeah - so it's the same fluid that started this thread. They only have this one MAX LIFE. Cool, and by all accounts it performs very well so far.Actually, they do.
Go down to Item 9
