I am coming up on my 7500 mile "free" VADIS adjustment. I was wondering if anyone knew if there is a list of codes and what they do?
Re: VADIS Help (wmurray926)
"search" is your friend
Normally listed as "Personal Car Settings", it took me a while to figure out what to search for the first time. I think this is the whole list:<p><br><A HREF="http://acctest.semcon.se/en-GB/P2X/comfort/added-or-altered-car-functions/VCC-249393.htm" TARGET="_blank">http://acctest.semcon.se/en-GB...3.htm</A><p>------------------------------------<br>FUNCTION FOR 2 STAGE UNLOCKING1 (US/CA functionality)2<p><br>S80 9499 637-8 <br>S60, S60 R 8645 453-5 <br>V70 00-, V70 R, XC70 01- 9452 950-0 <p>FUNCTION FOR DIRECT UNLOCKING¹ (EU functionality)¹<p><br>S80 9499 636-0 <br>S60, S60 R 8645 452-7 <br>V70 00-, V70 R, XC70 01- 9452 949-2 <p>Allows you to change the unlocking function of your car. <p>One-stage unlocking means that all doors and the tailgate/boot lid are unlocked by a press the UNLOCK button on the remote control once. 2 stage unlocking means that the first press on the remote control UNLOCK button will unlock the driver's door only. A second press is required to unlock the remaining doors. <p>To date cars built for the US and Canada have been supplied with 2 stage unlocking. Cars built for other countries are supplied with one-stage unlocking.<p>---------------------------------------------------------------------------------------<p>FUNCTION FOR CAR CONFIRMATION / ADD¹ <p><br>S80 9499 397-9 <br>S60, S60 R 8645 450-1 <br>V70 00-, V70 R, XC70 01- 9452 947-6 <p>FUNCTION FOR CAR CONFIRMATION / REMOVE¹ <p><br>S80 9499 398-7 <br>S60, S60 R 8645 451-9 <br>V70 00-, V70 R, XC70 01- 9452 948-4 <p>Allows you to add or remove the visual confirmation signal to your car. This function makes the car's direction indicators flash once on locking if all doors are closed, and twice on unlocking.<p>---------------------------------------------------------------------------------------<p>FUNCTION FOR AUTOMATIC LOCKING / ADD¹ <p><br>S80 01- 8637 408-9 <br>S60, S60 R 8637 412-1 <br>V70 00-, V70 R, XC70 01-, 01- 8637 410-5 <p>FUNCTION FOR AUTOMATIC LOCKING / REMOVE¹ <p><br>S80 01- 8637 409-7 <br>S60, S60 R 8637 413-9 <br>V70 00-, V70 R, XC70 01-, 01- 8637 411-3 <p>Makes it possible to retrofit or remove the automatic locking function in your car. This function automatically locks the doors in the normal way (not deadlocking) when vehicle speed exceeds 7 km/h. If the doors are unlocked using the central locking button while the car is moving they remain unlocked until the ignition key is removed from the ignition switch. If the door is opened from the inside, when exiting the car for example, the door is locked again when the vehicle speed exceeds 7km/h.<p>An open door will not be locked. The doors are not unlocked automatically when the speed falls below 7 km/h.<p>---------------------------------------------------------------------------------------<p>FUNCTION FOR ALARM ACTIVATION / DEACTIVATION VIA DOOR LOCK / ADD¹ <p><br>S80 9499 266-6 <br>S60, S60 R 8645 448-5 <br>V70 00-, V70 R, XC70 01- 9452 945-0 <p>FUNCTION FOR ALARM ACTIVATION / DEACTIVATION VIA DOOR LOCK / REMOVE¹ <p><br>S80 9499 267-4 <br>S60, S60 R 8645 449-3 <br>V70 00-, V70 R, XC70 01- 9452 946-8 <p>Makes it possible to retrofit or remove the alarm activation / Deactivation function via the door locks in your car. The function makes it possible to activate/deactivate the car's alarm via the door locks.<p>NOTE: The function for alarm activation / deactivation provides inferior theft protection as a further means of deactivating the alarm is created. The function is not approved by insurance companies in SE, NO, FI, DK, NL, BE, FR, UK. Check which rules apply for your insurance. <p>---------------------------------------------------------------------------------------<p>FUNCTION FOR HIGH SEAT TEMPERATURE 36-43°C¹ <p><br>S80 8651 379-3 <br>S60, S60 R 8651 381-9 <br>V70 00-, V70 R, XC70 01- 8651 380-1 <p>FUNCTION FOR MEDIUM SEAT TEMPERATURE 32-38°C¹ <p><br>S80 8651 382-7 <br>S60, S60 R 8651 384-3 <br>V70 00-, V70 R, XC70 01- 8651 383-5 <p>FUNCTION FOR LOW SEAT TEMPERATURE 28-35°C¹ <p><br>S80 8651 385-0 <br>S60, S60 R 8651 387-6 <br>V70 00-, V70 R, XC70 01- 8651 386-8 <p>Allows the seat heating in your car to be readjusted. The temperatures stated are approximate and specify low and high comfort levels. Cars built for northern Europe are normally delivered with 30-36°C (86-97°F) as low and high comfort levels.<p>---------------------------------------------------------------------------------------<p>CHANGE IN ACTIVATION LOGIC FOR PARKING ASSISTANCE¹ <p>There is an option of changing the activation logic for parking assistance via VIDA. With such a change, the parking assistance will be disabled at 15 km/h (9 mph) as in the original version. The system is only reactivated, however, when the button is pushed or reverse gear is engaged, unlike the original system in which the system is reactivated once vehicle speed drops below 10 km/h (6 mph). The system is always enabled during a new driving cycle.<p>Ordered according to separate procedures and downloaded using VIDA. <br>For cars without Deadlocks. <br>
