1 - 11 of 11 Posts
Need to see what the interior door handle mechanisim on the drivers door looks like.
It is currently not working and i have to roll down the window to get out!
I have picutres for you .....
just took them today fixing someones car.
if you want drive down tomorrow or friday and I can fix it quick for you
theres two green clips that hold on the threaded peices for the door lock itself
now on the back of the handler theres a small plastic peice that pushes it in .
I will have pics tomorrow problem or just call me and I can tell you how to fix it
2021 Volvo S60 T5 FWD
Re: (Chilled Man)
Sounds like he's talking about the inside handle. Little thing attached to the handle on the interior panel popped off?
(BTW, Justin got those panels off quite easily
Re: (StarmanDXE)
Quote, originally posted by StarmanDXE »
You're a lucky college guy having the Man living so close. Just be careful he doesn't part your car out accidentally
I've had 'that little thing' pop off in our XC after the dealer 'techs' worked on the locks.
yeah its the interior door handle - i will have to get at it!
Can those door clips be used more than once?
Re: (Bender)
Quote, originally posted by Bender »
Yes, but be careful. Press the center pin in, pull the clip out with something fork like. When assembling, remove the center pin, push the clip in, and then the center pin.
You'll need to remove the door handle cover to get to two torx screws also. I use just my fingernails, but a butter knife or 'bone tool' is less painful.
Re: (Mika)
Quote, originally posted by Mika »
http://********************/smile/emthup.gif
Quote »
He almost did!
LOL hey what can i say
what else do yo uneed ?
Re: VADIS Diagram request! (Bender)
Not sure if this is what you're looking for.
http://********************/smile/emcocktl.gif
1 - 11 of 11 Posts
