1 - 9 of 9 Posts
I'm trying to replace my vacuum lines. Some say I need to order 5mm, 6mm, 8mm and 10mm. Can anyone please confirm the exact size I need, before placing an order. Thanks.
Is there a recommanded OD size? (based on 5 mm ID)
anything from 4mm to 5mm is just fine.
I think you're talking about ID... I'm talking about Outside Diameter... ;)
I already have 5 mm ID hose (uninstalled yet) but the OD is very smaller than OEM hoses. I just want to be sure I bought the right thing!
Measurement done:
OEM Green and yellow hoses= 10 mm OD ; Red hose= 11 mm OD
My silicone hose= 9 mm OD (w/ 5 mm ID)
Will this silicone hose be strong enough?
well, make math, lol, 3 wall, 4mm, 3 wall, its about 10 mm OD. It doesnt matter if you have 10mm or 11mm, bigger is better cause it will not expand under boost. thats why a lot of people try to get 3 thikness wall.
I think I wasn't clear...
The silicone hose I have is thinner than OEM!
OEM : 3 wall, 4mm, 3 wall = 10 mm
Silicone: 2 wall, 5 mm, 2 wall = 9 mm
i recommend you to get at least 2.5mm wall, but remember, silicone is better than normal oem rubber lines.
1 - 9 of 9 Posts
