1 - 14 of 14 Posts
Protective plate beneath engine - V90 Cross Country 2018 - Volvo Cars Accessories
Recently got a coupon from VCNA and decided to purchase the skid plate for my V90 CC.
Its much beefier than the stock carpet style splashguard. Installation was pretty easy if you’re handy, the instructions from Volvo are linked here. Installation instructions I highly suggest the ”special drill bit” ( part# 9814112) to make it easier when drilling out the square holes where the plastic inserts are for the screws from the standard splashguard. It looks like a standard drillbit you could buy from Harbor freight the pictures of it are below, The Volvo one even included a hanger for the pegboard. Once I had the holes drilled I used paint and even put in some cavity wax to prevent any corrosion.
There are nutserts included with the installation kit used for mounting, I ordered this kit off of Amazon instead of buying the Volvo tool. Nutsert tool
Overall I’m pretty pleased with this for about 350 bucks
130639
130629
130631
130640
130641
130642
130643
I have ordered mine, thank for the instructions.
Reactions: rem0018
Is there access for oil change with the skid plate installed, or do you need to drop it to access filter and drain plug?
Nope, you got to drop it.
Does the dealer charge more for service?
Strange - one would think they could have designed in an access panel for that.
The plastic panel it replaces also needs to be dropped for oil changes. Plus, a skid plate wouldn't be of much use if it left a weak spot (or opening) right at one of the most vulnerable and easily punctured spots.
Juste got mine.
Do I need to.buy hardware???
Discussion Starter · #13 ·
Juste got mine.
Mine came with hardware but you will need the “special” drill bit (probably can pick this up at a harbor freight) and the nutsert tool.
Mine has zero hardware :(
1 - 14 of 14 Posts
