paulyz
· Registered
Discussion starter · #1 ·
I have two Volvo's, XC90 2016, which maps updates throught USB without problems, but V90 2047won't. I put same USB to V90, sensus show that USB connected, on top right appears circle for the second ( USB reading) and that's all, no update message or etc. Maybe Volvo dealer locked updated function? O where can be problem?
Discussion starter · #3 ·
you tried to redownload maps for v90? It is possible after first update, volvo to do some modifications to your usb drive or maps from xc90 not be compatible with v90
Yes, I tried various USB file system formats, etc., but nothing helped. However, when the dealer used their own USB, everything worked fine. They simply didn't have the time to perform the update, so they asked me to return later
Discussion starter · #4 ·
Okay, here's an update. I got a Kingston 64GB stick and uploaded the full Europe map. The stick worked, and Sensus asked for an update. I pressed "update," and strangely, the update circle was visible for about 5 seconds. After that, after about 1.5 hours, the system showed "loading" and later asked to turn off the car. Upon turning it on again, my navigation was gone. Every time I see the loading screen, there are no maps. The only solution is to visit a Volvo dealer. The Volvo dealer didn't help much. They updated the firmware Sensus, restored the old maps (v1166, the newest is v1433), but they can't update the maps, as Sensus doesn't accept them. The dealer doesn't know what to do. Funny, right? Dealer will ask volvo, interesting, we will get answer or solution will be "change all unit" :)
