Hi,
I'm a bit worried I might have a coolant leak, MY07 S80 V8. I got a low coolant level warning in the dashboard about three weeks ago. I filled it and today I checked the level which was nearing minimum again. No warning yet but definitely lower than when I filled it so I filled it again.
Is there anything I can do myself to troubleshoot this or do I have to have it looked at? I'm guessing it's just a leak somewhere since I a) couldn't smell anything resembling exhaust fumes in the expansion tank (indicative of a blown or leaking head gasket) b) it's only lost approximately half of the difference between max and min which I'd say isn't too much over the I think over 1000 km (625 mi) I've done since.
Discussion Starter · #2 ·
Bump... nobody has any clue? I've heard about adding dyes to trace leaks but maybe that applies to AC gas only, or is it something you could do yourself on a potential coolant leak? I'm guessing the coolant should leave residue at and near the leak source.
Was it a lot colder weather when the light came on?
Not really, no. 5-10掳 C maybe (40-50 F)
