1 - 18 of 18 Posts
I'm trying to decide whether I need to take any action wrt the rear springs on the 2002 V70XC that I recently purchased. The car has 125K on it. The front struts and springs were replaced prior to my purchase. The front spring part number is 31200372, which I believe is correct for chassis spring code 7G. The rear springs weren't replaced and are original as far as I know. The front of the car seems to be riding relatively high. I installed a set of spring adjusters in rear, which addressed the problem somewhat. Ride height measurements (measured from center of wheel to fender lip) are now as as follows:
LF: 17.5"
RF: 18"
LR: 16.75"
RR: 17.25"
Right now I'm leaning toward replacing the rear springs/shocks, but I wanted to check here on what's in the range of normal height. It seems like it would be ok as is for driving around town, but if loaded up for a trip might be a bit saggy.
Attaching a photo for reference.
I have rear spring chassis code B9, which I believe points to part number 8646865 for left side and 9473371 for the right side.
The front look right but the back looks a bit low... That's a darn pretty Ocean Race! Needs Pegs :rolleyes:
I doubt it's the springs... Shocks are far more likely.
Does not need PEGS
DOES need springs and they DO make a huge difference. With miles they weaken and sag
For reference my old 07 after new springs, shocks and struts all around.
Thanks. I'll plan to do the springs/shocks sometime in the next month or two as time allows. With any luck I'll find the original sway bars from my R and install those at the same time.
This car doesn't have nivomats so no way it can be the shocks. Nevertheless, once in there I'd replace both.
I installed the new rear springs and shocks this weekend. I installed an IPD Sway bar as well, since I had everything apart anyway. This wasn't a very pleasant job, but I'm glad it's done. I ran out of time and will have to do the front sway bar another time. The rear bar makes a nice difference in combination with the new springs and shocks - the ride is a bit less floaty. The ride height in rear is noticeably improved although t's not very apparent in the photo below. I haven't taken any measurements yet, but will do so tomorrow.
IPD sway bar as installed
Stock bar vs IPD. The stock bar is sort of a joke.
Original shocks and springs look pretty beat.
While I was at it I replaced the TCV hoses. Another not so pleasant job.
Discussion Starter · #10 · (Edited)
I figured that between the K&N air filter and the IPD HD TCV I'd be in for a lot of counseling. I always monitor silicon levels in the oil with oil analysis and the K&N filters have always provided good filtering... for me... in my cars... in my location.
Replace your K&N with a paper filter. K&N can't filter for crap, by design.
New measurements:
LF: 17.5"
RF: 17.75
LR: 17.25"
RR: 17.25"
This is without any spring adjusters installed, which would have added 1/2" to the original springs.
LOL, I Know. It's like a paper clip. I had my mechanic install the sway bars and he was laughing at the size difference.
BTW on K&N Filters:
The stock element and stock box flows very well. Even with my setup my MAF register ~240g/s (or approx 300bhp). With the AEM dryflow filter the number increases by 10g/s, but low end and turbo spool is still the same. The oil from the K&N is also known to contaminate the MAF and cause errors.
IPD TCV:
Honestly, should have left it stock.
Discussion Starter · #13 ·
When I first saw that rear sway bar I didn't even recognize it as a sway bar. I thought it was a vacuum line at first... so small. :)
BTW on K&N Filters:
IPD TCV:
14Mm vs 22mm
Discussion Starter · #15 ·
Discussion Starter · #16 ·
Front IPD sway bar is in. The job wasn't as bad as I expected. I used an engine support bracket to support the engine from above. No major hiccups in the procedure. I just made sure to be careful with the various brake, vacuum, and electrical (O2 sensor) lines. I used a combination of the IPD instructions and the instructions posted by StealthyS60R back in 2010. The car feels pretty good. Just need to get it aligned in the near future.
Discussion Starter · #18 ·
1 - 18 of 18 Posts
