I'm curious of other experience with using other than volvo brake pads..
whether using other than volvo genuine parts for brake pads will cause the brakes to squeal?
the reason i ask is because i have a very convenient service station to my home. they can replace my front ceramic pads made by Akekabo.
when i called the service station that specializes in volvo they said don't use anything but volvo pads otherwise the brakes will squeal.
Re: v70xc 2001 front brake pads (sharpeirescue)
The issue is usually with cheap brake components from the local Pep Boys/Auto Zone/Advance; high quality parts tend to be fairly issue free.
I'm running Akebono Euro pads with no squeal issues. Just be generous with the anti-squeal grease they provide (applied to the back of the pad).
Re: v70xc 2001 front brake pads (VTT5)
Quote, originally posted by VTT5 »
Akebono front and rear, Brembo rotors front and rear. I have about 70,000 miles on mine and about 1/2 the pads left.
If you are not doing new rotors, make sure they are turned with an on-car brake lathe.
I just HAD to do brake hoses (one split), used the IPD stainless steel ones. HUGE improvement in brake feel!
Landru
2001 V70 T5M 202,000 miles
Re: v70xc 2001 front brake pads (Landru)
Also running the Akebono/Brembo combo...
http://********************/smile/emthup.gif
I too have both my V-70s on the brembo rotors and akebono pads....virtually no dust, oem braking, squeal free ... I have 10k on my wifes' and no issues whatsoever, only 2k on my car, I would highly recommend this setup...FCP GROTON has the compete package for 355$ shipped. JHW ...ps My indy mechanic recommended replacing rotors and pads as a package to prevent squealing...he did not recommend turning the rotors if I was going ceramic...so I replaced rotors and pads
