1 - 8 of 8 Posts
I have a '99 model with a problem. Former owner, who lost the key, tried to pick the lock. Bad idea.. I know that the car ran, but I'd like to know that the engine still does. Can I force the engine to run with out the steering column engaged ? Sort of hot wire it to hear the engine run?
bk
I am unfamiliar with Volvos. But if I remove the ignition and the starter (from the whole system), wont the thing start?
No. Ecu needs key chip handshake to initiate fuel pump.
The easiest and cheapest attempt would be to get a key, cluster, ecu, tcu, immobilizer from a donor car and swap it all over.
OK. I don't have any of those things. I assume that you mean the key and cluster (from the dashboard), the ECU and the TCU are down in the area near the power steering pump. Where is the immobilizer situated?
Can't a dealer provide a key based on VIN?
Best way to keep it easy and maintain stock
condition and vehicle history. Worth a call...
There is no key produced by vpn. The dealer wanted to tow the car 45 miles to the dealer, and have the key and whatnot replaced at $400-500 dollars, and have car re flashed, then we could see if the engine is worth saving.
Or, perhaps not..
945
How much would this cost? No point in buying a "new" car in replacing the old one...
1 - 8 of 8 Posts
