1 - 16 of 16 Posts
Re: V70R tire pressure (row)
<A HREF="http://forums.swedespeed.com/zerothread?id=37839" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=37839</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">Any reccomendatons for tire pressure? mostly highway driving in Northeast.</TD></TR></TABLE><p>Anyone up for starting this debate again?<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>I am running Mich. Pilot Sport A/S's and I am running the recommended (in the fuel door) 35psi per tire...which is the light load recommendation from Volvo. <p>Dropping from 37 to 35 has noticably taken the edge off of the suspension. In a good way. Steering feel has not been compromised.
Re: V70R tire pressure (needsdecaf)
17" F1s at 36psi
Re: V70R tire pressure (TexasV70R)
I run 36 PSI in my 17" Pirelli Pilot Sport 2's on a 2004 V70 R. Seems to work perfectly. Mostly mountain twisty driving. oclv
Re: (R_Rated)
36-37 for PS all seasons. <br>Your dealer is a *&&%^$% idiot and has absolutely no idea what he's talking about. NO tire for the R should be run at those pressures
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">Any reccomendatons for tire pressure?</TD></TR></TABLE><p>17" Goodyear F1s... 36 front, 33 rear. If'n I was to go long distances with a load, would up the rear to 35 or so.<br>
Re: V70R tire pressure (oclv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>oclv</b> »</i></TD></TR><TR><TD CLASS="quote">I run 36 PSI in my 17" Pirelli Pilot Sport 2's on a 2004 V70 R. Seems to work perfectly. Mostly mountain twisty driving. oclv</TD></TR></TABLE><br>Michelin's...PS2's. I'm still running the Pzero's, sticky and quiet until the last 4k miles. 36 psi.
Re: V70R tire pressure (TomW)
what is the reason for different pressure front vs. rear? thx
Theoretically more front pressure may give a little oversteer but in an AWD Volvo they should be the same.<br>He is i<U>ncorrect </U>in running different pressure on an R<br>34-37 <B>unloaded</B> is just fine<br>37-39 <B>loaded</B>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">what is the reason for different pressure front vs. rear?</TD></TR></TABLE><p>More weight on the front. Run the rears at 36 without a load and the ride suffers.<br>
Re: V70R tire pressure (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">He is i<U>ncorrect </U>in running different pressure on an R<br></TD></TR></TABLE><p>But of course. We should all just go to the <B>real</B> authority...<br>
Since you are <I>probably </I>the ONLY person to run staggered tires pressures<br>'ya think we're all maybe on to something?<br>(I've tried every pressure which way from Sunday, whatever they are, even all around seems to work better)<br>I don't disagree with you in general, I run 2 to 4 lbs more in the fronts of my<B> FWD </B>Volvos, but it doesn't work as well in an R
1 - 16 of 16 Posts
