IIRC the V70R rear swaybar will fit the S60R and the V rear swaybar is 22mm where the S60R is 20mm. Do I have that correct?
Re: V70R Rear Sway Fit S60R? (nikhsub1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>nikhsub1</b> »</i></TD></TR><TR><TD CLASS="quote">IIRC the V70R rear swaybar will fit the S60R and the V rear swaybar is 22mm where the S60R is 20mm. Do I have that correct?</TD></TR></TABLE><p>I think you're right about the diameters, but I'm almost 100% positive that it'll fit. <p>IIRC, RKelly had (or still has) a V70R rear bar on his S60. Not sure if he ditched it when he put on the TME's.<p>Speaking of which, where IS Kelly? Must be moving!
Re: V70R Rear Sway Fit S60R? (needsdecaf)
Yeah I got my answer and my $50 22mm rear sway! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
nikhsub1, Yap R Kelly has my V70R OEM bar and he installed it on his S60R at the same time as his TME springs. The thing is, you need to get the poly bushings from ipd to really tighten things up. If I remember right they cost him about $35. And yes, Kelly is either moving or TDY (duty at another station) at the present.
