1 - 12 of 12 Posts
hi there... i own a v70r 2.3 awd and i have vibration problem...the center bearring driveshaft is fuct! The dealer sell the driveshaft 1,200 $ (canadian dollars) Any alternative..... Web site etc.. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: v70r 98 driveshaft option ? (hAmel)
Yes, the price is about right and is common anytime after 90K miles<p>...and no, no alternative unless you want to chuck the driveshaft and run FWD only.<br>It WILL drive very well that way, also a good way to test, if it IS the driveshaft
Re: v70r 98 driveshaft option ? (gdogg16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>gdogg16</b> »</i></TD></TR><TR><TD CLASS="quote">Volvo has a rebuild kit for the shaft, it's about 200 in parts. Search for the PN.</TD></TR></TABLE><br>No,<br>I just went thru this.<br>His CENTER (internal-middle) bearing is shot (as mine was) not the ones at the end.<br>Cannot be repaired like the ends ones which now can be replaced
Re: v70r 98 driveshaft option ? (JRL)
Mine did that when I bought it at 93K miles. They've done a lot of front end work and it's smoother, but I haven't replaced the driveshaft. It still does vibrate a bit at speeds over 65 mph but much less. Is this a serious problem if it's not fixed?
WELL....Im not really interrested to remove the AWD........ There is 2 models of driveshaft for 98... both fit ? same weight ? any other driveshaft fit on it ? 98-2006 same drive shaft ? Cuz i will try to fin a use driveshaft on ebay or other place.... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Just interjecting a dumb questions here...<br>Known good wheel balance?<br>No mud or buildup inside the rims?<br>Just Checking...Sometimes the cheap,<br>simple stuff can save the bucks! Good Luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>hAmel</b> »</i></TD></TR><TR><TD CLASS="quote">WELL....Im not really interrested to remove the AWD........ There is 2 models of driveshaft for 98... both fit ? same weight ? any other driveshaft fit on it ? 98-2006 same drive shaft ? Cuz i will try to fin a use driveshaft on ebay or other place.... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> </TD></TR></TABLE><br>You don't want to do that.<br>Why would you start off by buying a USED driveshaft, the bearings WEAR OUT!!!<br>The labor isn't much, (1 hour at the most, usually less), do some shopping and find your best deal on a NEW driveshaft<br>If there were two in 98 then by all means get the right one, there obviously is a reason. Perhaps the earlier ones were more problematic?<br>(98-00 probably fit the same, 01 and newer, no)
There's a cut-over for the driveshafts (same one for an XC). It goes by VIN#. Common thing for mfg's to do when they change something in the spec of the car, parts don't always change w/ model year. I'm having this same issue w/ my '98 XC now. But, it's a low speed vibration, and seems to only happen occasionally on low speed semi-sharp turns. More of a 'thump-thump-thump' than a typical vibration. Haven't been driving it much (at all) lately. Need to get it on a lift and see if it's the center joint or one of the end joints. We looked at it a while ago, and it might be the front joint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Yes, the price is about right and is common anytime after 90K miles<p>...and no, no alternative unless you want to chuck the driveshaft and run FWD only.<br>It WILL drive very well that way, also a good way to test, if it IS the driveshaft</TD></TR></TABLE><p>??? I've heard that it's not a good idea to run w/o the rear diff connected. Confuses the computer, etc. And, if the AWD unit is fragile enough to take a crap if the tires vary by 1/16th of an inch, front to rear, I can't see that running w/o the rear for any length of time would be good for it.
Re: v70r 98 driveshaft option ? (Mk1Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Mk1Racer</b> »</i></TD></TR><TR><TD CLASS="quote"> But, it's a low speed vibration, and seems to only happen occasionally on low speed semi-sharp turns. More of a 'thump-thump-thump' than a typical vibration. Haven't been driving it much (at all) lately. Need to get it on a lift and see if it's the center joint or one of the end joints. We looked at it a while ago, and it might be the front joint.</TD></TR></TABLE><br>Just had the EXACT same thing on a 98 R I just sold which required a NEW DRIVESHAFT to fix the problem.<br>The replacement of the (obviously bad) front joint (rear seemed fine) didn't help one bit.<br>Oh, it gets worse as you continue to drive it, fork out that $1000
Try contacting these guys...<p><A HREF="http://raxles.com" TARGET="_blank">http://raxles.com</A>/
1 - 12 of 12 Posts
