Alors je te salue avec mon accent Québécois !I am French so really easy ^^ anyway, the pictures speak louder than any words
YesThey are whiter, right ?
Je te retourne le salue et j espere pouvoir te rencontrer un jour ;-)Alors je te salue avec mon accent Québécois !
Good to know nd it will be . great addition in this setup...Hopefully, it will be done between August 1st and 6th ;-)BellevillV70 said:Don't bother with the OE lights....get these, MUCH brighter. Only issue with them is to trim the fingers off the side with a razor as they are a little too tight to fit. Great update from stock or addition if don't have any. I replaced liftgate and trunk one with these.
https://www.ebay.com/itm/282423346452
Glad it was useful !Stef1, you are a good man!!!
I have just done the install, however I cheated...
I just stuck my hand in, grabbed the plug out of the foam pouch, then cut a hole for the light and ALL DONE!!!
Thanks for your great write up!!!
I was wondering whether that might be possible - avoiding all the grief of broken retaining clips. Thanks Stef and ope!Stef1, you are a good man!!!
Good job !!Hi Stef,
Thanks again for doing it and I finally did it too last weekend.
Here for more
2 things that come in my mind
-I highly encourage to remove the plastic with leather (close to rear door) last... If you try first, chance will be that you will break a clips (like me). When I did it last, it was easy to remove it and access to it
-Anyone who is doing this should think of adding a second lamp for the left side. You will be bluffed by the result ;-)
I do not think you can edit. I tried many ways for my thread and same. Looks like only Admin can do it (TBC)Good job !!
Now, can someone help me correct the typo in the thread title ?![]()
