V50/S40/C70/C30 P1 big brake kit
5.5K views 33 replies 10 participants last post by  SameLosingLuckyNumbers
#1 · (Edited)
$0.00
Check price
Philadelphia, Pennsylvania
Ceika big brake kit that came off an awd V50. I don't know much about it as it was installed by the previous owner.
The kit has 330 x 28mm rotors with 6 large piston calipers in the front (they might be x-large pistons, but I can't tell from the website)
304 x 22mm rotors with 4 x-small piston calipers in the rear. This includes a caliper mounted e-brake mechanism so you can retain your e-brake with the stock cables.
With the above options this is a $3,435 kit assuming the front pistons are the "large" size and $3,607 assuming they are "x-large"
I'm not sure what kind of pads are included, but there is plenty of meat on them.
#17 ·
#18 ·
The ceika calipers have a banjo fitting. These lines are specific to the kit. I bought them to replace the lines that came with it because they were in rough shape. The lines will not fit any P1 unless you have a ceika kit or calipers that utilize a banjo fitting and mount up in approximately the same spot.
To be specific- this ad is for the calipers + rotors + the new lines. Nothing has changed except I threw in a new set of lines to facilitate the sale.
#19 ·
I hope I am not resurrecting a dead post but are these still available?
#25 ·
Price drop. Whoever can physically pick these up can have a 4 wheel big brake kit for the price of new pads and rotors. And I'd even consider trading for p1 parts. A screw broke off one of the pad retainers and I'm done staring at this bbk. Come pick it up and it's yours.
#26 ·
View attachment 212344 View attachment 212345 View attachment 212346 View attachment 212347
Located right outside of Philly.
My son texted you how far from the airport are you.
Little low on. Cash but mid week if you still have them I would like to send you the cash, PayPal, venmo zill and have you hold them for a week until till I can get arrangements to flight out there and pick them up
