1 - 9 of 9 Posts
Slightly uneasy about installing my IPD HD TCV.<br>Can anybody confirm correctness of notes in this pic?<p><IMG SRC="http://i150.photobucket.com/albums/s105/goddamnswede/TCV.jpg" BORDER="0">
don't worry about where the hoses go you will get confused some of the pics online are incorrect.<p>The ports on the IPD HD TCV are color coded and match the ones on the stock TCV. (Next to each port there is a dot yellow red and i think blue but not sure) anyways just match up the colors and u are good 2 go.you wont see the dots untill close inspection of the stock valve.
Yup, the s60 valve is it. Bracket wont match but it can be fixed in position with a strip band.<p>Ok, color codes on the stock valve should make it easy.<p>Got another explanation from Ipd Lucky <br>Guess the pic i posted was misleading regarding turbo connection.<br><A HREF="http://forums.swedespeed.com/zerothread?id=120190" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=120190</A>
Re: (goddamnswede)
So How the Difference and - Some Sort of Seat of the Pants Feel .<p>Smoother ? <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
I`ll make sure to let you know when its done. <br>If i remember correctly Pas4ion reported smoother boost. <br>Hopefuly it will limit boost spikes to a minimum too..
Re: V50 HD TCV (goddamnswede)
BTW, that picture is wrong. I took that picture so Lucky from iPd to confirm. Two of the hoses I labeled were mixed up. It's explained somewhere in the iPd HD TCV thread.
I got the Turbo and the vent (other) backwards in the picture.<p>See here:<br><A HREF="http://forums.swedespeed.com/zerothread?id=96401&page=14#1052257" TARGET="_blank">http://forums.swedespeed.com/z...52257</A>
1 - 9 of 9 Posts
