Hi folks,
I've got a 2008-2009 C30 T5, and I want to fit the iPod/USB lead to the stereo. Volvo wanted £981 and I refuse to pay so much for that. Here's the stereo specs;
Dynaudio
6 CD Changer
Bluetooth Handsfree
Rear Parking Sensors
RTI
Obviously with the 6 CD Changer the USB is removed, but it is still possible to add the interface.
Which part numbers do I need from the following page, with the above specification?
http://accessories.volvocars.com/en-gb/C30/Accessories/Document/VCC-449090/2008
I'm guessing I definitely need 30758237, but do I then need 31201196? Or 31201524?
This quote is confusing;
If both the USB and iPod® Music interface and the Handsfree System with Bluetooth are to be installed, use one of the following installation kits, however, only one installation kit is required if you install these at the same time:
I have BT handsfree already, does this affect anything?
(By the way I know I'll have to take it to volvo for the software update but I can live with that, just)
Many thanks to whoever can help :)
Discussion Starter · #2 ·
Do these S40 part numbers apply to the C30 too?
Not sure what the second part number is, but the first is software that you have to load into your car to get everything to work. There are 3 software applications, the one you referenced installs only USB support, but the one you want is the one that has both USB and iPod support. You have a 2009 with the performance sound system, so you would need the following:
31260795 $247.90 (this is the actual box that reads data from your iPod)
31201196 $25.57 (this is a harness that connects the above box to the CD player in your car)
31316394 $63.02 (this is a cable that has a USB port and iPod dock connector that plugs into the main box)
31201260 (this is software, so you would probably have to go to the dealer)
Total of $336.49 + $21.87 shipping from Palisades Volvo (http://www.palisadesvolvomazdafactoryparts.com)
If you have the volvo bluetooth in your car, you would need 31201523 instead of 31201196.
did you find an answer by any chance?
