1 - 6 of 6 Posts
C30Rev
· Registered
Discussion starter · #1 ·
I traded my S60 with a 2011 C30 T5 and i took this kit out of the car. I have no use of this iPhone interface kit anymore.
This interface will let you charge and play your iPhone/iPad/iPod plus androids with 3.5mm cable directly into your Volvo S60/V70's speakers and be able to use your steering wheel controls in a CD quality sound.
I bought it new from USA SPEC for $120 plus the factory navigation CAS for $25.00. I'll take and good or reasonable offer. This kit is in perfect condition however i do not have the original packaging box.
Here is a little description from the manufacturer.
PA11-VOL (Volvo S60 / 2002, Either)
Notes:
Connect behind the Radio Do Not Use OEM pre wired cable Works with NAV Radio Must Order CAS-VOL NAV Cable
Description
PA11-VOL
Connect, control, charge, and play an iPod through your factory Volvo Radio
Supports Spotify, Pandora, Livio, iHeartRadio, Sirius XM Apps!
USA SPEC PA11-VOL Features
Connect, control, and charge your iPod, iPhone, and iPad from your Factory Radio.
Works with and charges iPhone 5 but must be used with Apple's lightening to 30-pin adapter.
Works with and charges iPhone (3G, 3Gs, 4, 4s), iPod Classic, Nano, and Touch.
Compatible with iOS 6.1.2.
Connect and play a 2nd audio device through your car stereo.
You can connect an addition auxiliary input into your facotry radio for audio device such as DVD player, satellite radio receiver, or MP3 player to the AUX INPUT on the interface. The AUX input is also selectable from your radio.
You have multiple modes to control an iPod.
Please Note
For 1994 - 2000 Volvos - Please use our PA11 HON and CBP-VOL cable.
Vehicles with Nav radios requires an additional cable CAS-VOL_NAV must be purchased separately.
Code: PA11-Vol
Manufacturer: USASPEC
Weight: 1.400 Lbs
Will this work on a 05 s60r with an hu850?
Also I'll be using an iPhone 5 and I will be using the adapter cable from the old iPhone charger to the new one... Is this compatable with regards to the new operating system?
Discussion starter · #4 ·
Sold!
Discussion starter · #5 ·
Sorry, the item was shipped this morning. But yes, it does work on HU-850 with old iphone cable to new lightning connector.
1 - 6 of 6 Posts
