1 - 12 of 12 Posts
heya guys,<p>need urgent info plz...just sent my 2.5 xc90 year 2004 for its 90000km service which requires its timing belt to be replaced...i have also been recommended for the auxiliary belt and tensioner to be replaced...is this necessary<p>however my important question is on what engine oil shld be used...the authorised service centre i sent my car to insist that i shld use Castrol 0W/30 grade... However i just inquired with authorised service centre B for a second opinion and they said that Castrol 10w/60 or Shell 5w/30 shld be used and the 0W/30 is only for 2.5 XC90's year 2005 onwards.the .. Now which service centre is telling the truth and i am confused..<p>any help would be greatly appreciated..<br>thank you <BR><BR>
<i>Modified by bikz at 1:05 AM 3-31-2009</i>
Re: URGENT HELP... engine oil grade for 04 XC90 (bikz)
Take the new belts as recommended... <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>First don't panic <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> .... The grades are acceptable as follows:<p>0W30 <br>5W30<br>10W30<br>0W40<br>10W40<br>20W50<p>The grade selected can correspond to the temperature the vehicle is being operated in lighter for cold heavier for hot. Lighter weight oils will reveal leaks faster and break down quicker if raced on. Lighter oils will also provide an increase in gas mileage as the engine doesn't have to work as hard through it. Take swimming through water to mud as an analogy. You would tire alot faster in the mud... K back to oil... You will want to use a heavier oil for more spirited or harder driving, example would be towing or constant mountainous driving... Last pick a quality oil. I use either AMSOIL or Redline... Ultimately it's up to you, but the oil is the blood of your engine if you could put the best in your body wouldn't you. <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> 10W60 <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0">
Re: URGENT HELP... engine oil grade for 04 XC90 (kmg_S60R)
thanks s60 R....<p>i actually contacted the manufacturers here in Malaysia (our cars are locally manufactured/installed here by Volvo Cars Malaysia (VCM)) and they told that the right oil recommended for my car, based on our weather is the Shell 5W/30....and this is the oil which has been used throughout i think as well....<p>
<p>5w-30 is a good overall choice..
Re: URGENT HELP... engine oil grade for 04 XC90 (dmd)
I would never ever use 10W-60, and certainly not in a tropical climate. Extremely wide-range oils use too many additives to achieve it, and as a result don't have the same longevity as straight oils. I'd use 10W-30, personally, and I only go to 5W-30 in the winter here in New England.<p>Tom.
If you have a Turbo, then use synthetic oil. Any Synthetic xW30 or xW40 will do just fine.
Re: (ChicagoT5)
Not trying to hijack the topic but I have a question,<br>how many qts of oil do I need for an V8? My first oil change is coming soon.<p>Tom<p><br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bikz</b> »</i></TD></TR><TR><TD CLASS="quote">2.5 xc90 year 2004 for its 90000km service which requires its timing belt to be replaced...</TD></TR></TABLE><p>Way too soon. See Owner's Service Operations Schedule (192K km / 120K miles).<br><BR><BR>
<i>Modified by Tao at 8:40 PM 4-2-2009</i>
Re: (Luniew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Luniew</b> »</i></TD></TR><TR><TD CLASS="quote">Not trying to hijack the topic but I have a question,<br>how many qts of oil do I need for an V8? My first oil change is coming soon.<p>Tom<p><br></TD></TR></TABLE><p>7
Re: (m1964)
thanks,<p>owners manual says 7.1qts, warranty and service record book says oil volume 6.1qts and I asked the tech when I picked up the oil filters and they told me 8qts.<br>I will fill it up with 7 and check the dipstick.<p>Tom
RYOM <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <A HREF="http://apps.volvocars.us/ownersdocs/2004/2004_XC90/04xc90_09a.htm#pg127" TARGET="_blank">http://apps.volvocars.us/owner...pg127</A><p>...and here's a link to the Volvo 2004 All Models Maintenance Chart:<br><A HREF="https://www.customers.volvocars.com/owners/docs/2004/2004_maintenance_charts/2004_maintenance.html" TARGET="_blank">https://www.customers.volvocar....html</A><p>LTA<p>
Re: URGENT HELP... engine oil grade for 04 XC90 (Tao)
heya guys<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Tao</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Way too soon. See Owner's Service Operations Schedule (192K km / 120K miles).<p><i>Modified by Tao at 8:40 PM 4-2-2009</i></TD></TR></TABLE><p>our service book says 90k km...i triple checked....
1 - 12 of 12 Posts
