Re: Upgrading Injectors (Cicada)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Cicada</b> »</i></TD></TR><TR><TD CLASS="quote">straight upgrade, or do oyu need to do the fuel pump, too?</TD></TR></TABLE><p>more importantly you need it programmed in your ECU
No need to upgrade fuel pump.<p>But you do need to tune the ECU else you will be running a very rich mixture...you may even drown your engine if your injectors are big enough. You will also need to insert a new figure for the calcualtion of fuel consumption as the travel computer's FC calculation will be based on the smaller fuel injector.<p>Mine was done by MTE and based on 750cc injectors <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: Upgrading Injectors (R_Rated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>R_Rated</b> »</i></TD></TR><TR><TD CLASS="quote"><p>more importantly you need it programmed in your ECU</TD></TR></TABLE>IPD have that covered? in the end, im probably goign to be going for the same setup as you have.
