I was changing the rear brake pads and rotors today and found some unusual pad wear. The right rear pads are worn unevenly within each pad (See pic). I think the only way this could happen is if the pads ears were not moving freely on the caliper. I would expect a problem with the caliper piston to cause uneven pad wear side to side, with each side flat, or premature wear with flat pads. I will be properly prepping the caliper mating surfaces.
Any other thoughts as to the etiology of angled pad wear?
(previous owner or shop did last brake job)
