Hi,
I need to replace me two front tyres, I have the 18" Mirzam wheels, currently running factory PZeros. When I ring around for replacements I keep being offered re-enforced tyres.
Are re-enforced (Extra Load) tyres needed for a C70? (Dealer was no help, couldn't tell me
Also can anyone suggest a good all season tyre? Quite tempted to try Bridgestone/Goodyear
Thanks
Modified by cm at 11:25 AM 6-24-2009
Re: Tyres (cm)
Hi,
Check an earlier post about the Nitto tires...
Not sure what they mean by reinforced tires. Could be a unique term not used here in the US. My first thought is they mean run-flat tires (many C70 don't have a spare tire). Run flats are simply a tire with very strong (reinforced sidewalls) so they can function safely without air if the get a flat. Ride very harsh and often require a special rim.
hope this helps
Re: Tyres (weatherman)
If you otherwise liked the P-Zero Rosso summer tires that came with the 18" wheel option, but prefer an all-season tire (or if you are unhappy with how fast the Rosso's wear out), one option to consider is the all-season version of the P-Zero Nero. They won't be as sticky as the Rosso's, but will be better during cold weather, and also have a substantially longer tread-wear rating. (Note that there are also summer versions of the P-Zero Nero - but I think these also wear faster.)
