1 - 20 of 22 Posts
i noticed one my stock 18 pegs with rosso's was looking a bit low<br>i checked the tyre presure in question which had 28 psi<br>in fact all of the tyres had 28 psi,<br>in the petrol flap it states 35 psi,<br>and i remeber prevoius threads talking about the 36-39 psi range<br>anyone advise what i should be running at, volvo main dealers had the car checked a few times and must have set the presures at 28 psi.<br>what do you think fellow r owners
Re: tyre pressures ?? (DANIELSWEM)
Conventional wisdom is <B>at least </B>36PSI all the way around. I run 38PSI in the front to help reduce (albeit slightly) understeer.<p>moddeR
Re: tyre pressures ?? (moddeR)
I used to run about 34 with Pegs with no ill effects but 29 IS too low<br>I run 37 with Michelins (softer sidewall)
36-37psi with the 18's seem like a decent balance for me.
Re: tyre pressures ?? (MagoonR)
What about the 17", what is recommended?
Re: tyre pressures ?? (S40 T5R)
I run 37.5 lbs (I have a digital tire pressure gauge <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> ) for regular street driving, but I don't normally load the car up.<p>So far I have a bit less than 11K miles on the original tires and had expected to have to replace the tires after my "safety driving" experience.<p>Upon rotating and inspecting each tire, I found there was 7/32 tread left and they were relatively evenly worn. Except for the outer edges which had a slight bit of chunking which extended to a a lesser degree as one looked toward toward the middle rib of the tire. Interestingly, some of the rubber had gotten hot enough to melt and then resolidify on the tread on the outer to middle of the tread. <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
Re: tyre pressures ?? (Lead Foot 60)
Well, you can't be driving all <I>that</I> hard if you have 7/32 left,<br>that's nearely 3/4 tread!!!<br>
I like this:<br>38 front<br>39 rear<p>I have Mich. PS2 95Y<p>LTA<br>
The manual says 35 psi minimum, 39 optimum at 68 F. I ran 35 psi for comfort. 28 is way to low.
Re: tyre pressures ?? (BrunoS)
Goodyear F1s: 38psi
Re: tyre pressures ?? (TexasV70R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>TexasV70R</b> »</i></TD></TR><TR><TD CLASS="quote">Goodyear F1s: 38psi</TD></TR></TABLE><p>F1s and NYC potholes: 39-40psi<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>DANIELSWEM</b> »</i></TD></TR><TR><TD CLASS="quote">i noticed one my stock 18 pegs with rosso's was looking a bit low<br>i checked the tyre presure in question which had 28 psi<br>in fact all of the tyres had 28 psi,<br>in the petrol flap it states 35 psi,<br>and i remeber prevoius threads talking about the 36-39 psi range<br>anyone advise what i should be running at, volvo main dealers had the car checked a few times and must have set the presures at 28 psi.<br>what do you think fellow r owners </TD></TR></TABLE><p>make sure you don't go over the recommended, not even 1 psi. 2 or 3 psi below is alright. your tire wear will be centered and you will lose majority of your tracctions if your tire is over-inflated.
Re: tyre pressures ?? (stevectsai)
Hey Lead Foot, when you are ready to sell your car, call me. I will be looking for a nicely treated R. 11,000 miles with 7/32" left, thats amazing. I have not gotten more than 10,000 to 10,500 miles out of any tires yet. I have had two sets of the OEM Pirellis, three sets of Michelin PS 2's, one set of Blizzaks, and two sets of winter sport M3's and I just hit 80,000 miles. I just bought my third set of winter sport M3's. (from Jay). Getting back to tire pressures, I run 37 lbs in mine and it seems to be fine. oclv
Re: tyre pressures ?? (LTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LTA</b> »</i></TD></TR><TR><TD CLASS="quote">I like this:<br>38 front<br>39 rear<p>I have Mich. PS2 95Y<p>LTA<br></TD></TR></TABLE><p>Funny, I was thinking my R was feeling a bit sloppy these days and sheesh, they were down 2psi. I'm sure I checked and adjusted them only a month ago (more or less). <p>LTA<br>
I ran mine at 38-39 (digital guage usually cold measurements) on 17's, I think it may have been a bit too much. The tires are worn much more on the centers than it is on the edges. I put it back to 35.
Re: tyre pressures ?? (pitogo)
i checked my tires the other day because htey looked REALLY low...<p>26.5! lol..<p>so i filled 'em up to about 34.5-35<p>i have nitto 555's on 18" pegs.
Re: tyre pressures ?? (Cicada)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Cicada</b> »</i></TD></TR><TR><TD CLASS="quote">i checked my tires the other day because htey looked REALLY low...<p>26.5! lol..<p>so i filled 'em up to about 34.5-35<p>i have nitto 555's on 18" pegs.</TD></TR></TABLE><p>bet your mpg took a hit as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>stevectsai</b> »</i></TD></TR><TR><TD CLASS="quote"><p>bet your mpg took a hit as well.</TD></TR></TABLE><p>I run 36 psi in my Pilot Sport A/S. <p>A bit on the low side, but my 4C seems to be harsher over bumps than most (I swear this changes from drive to drive but that's another story) and 36 offers a good compromise between comfort and performance. <p>Of course, I bumped them up around the holidays when we were packing the car with gear.
Well, it just so happened that today my car went in for its 14.517K mi service. The dealer was going to do a balance and rotate but they called me to say the tires have no meat in the centers...arg so they'll just leave it. I will have to put on the winter boots pretty soon and replace em tires next summer. So much for higher pressures, its a trade of on wear and fuel efficiency.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pitogo</b> »</i></TD></TR><TR><TD CLASS="quote">I ran mine at 38-39 (digital guage usually cold measurements) on 17's, I think it may have been a bit too much. The tires are worn much more on the centers than it is on the edges. I put it back to 35.</TD></TR></TABLE>
1 - 20 of 22 Posts
