I had my endlinks changed (cheapies) and within 2 weeks I'm getting creaks and groans. I checked the endlinks and they seem ok, they articulate smoothly. I took a look and noticed my passenger side sway bar bushing looks like its binding, It actually has twisted within the cradle a little bit. Cradle is tight
Are there replacement bushes? Because I thought u couldn't put new ones on these bars because of the design? Yes no maybe so?
My bushings look the same way as you describe. I find it a waste of money buying expensive endlinks. They last just as long s the cheap ones. I don't think there is a replacement for the bushings, have to get the whole bar...........
Check your control arm bushings and spring seats.
Search Ebay or Summit Racing for Prothane poly sway bar bushings. They make poly bushings. The replacements are split and can be put over the bar after you cut the remains of the failed ones off.
