1 - 20 of 36 Posts
I wrote this up when the alternator failed in my 2006 XC90 V8 - the original and updated article is on my website here:
http://andrewpeng.net/cars/2006-volvo-xc90-v8-awd/alternator-replacement
The article is copied below - you can click on all the images to see a full-size image. Hope this helps someone!
On 20120208 at 92,415 miles, I got a red triangle indicator and a "POWER SYSTEM SERVICE URGENT" message in the message center, along with the battery warning icon illuminated in the idiot-light panel on the right, followed by a MIL/CEL shortly after:
Since I was already close to home, I shut off all the accessories like air-con, lights, and radio and drove home. When I got home, I checked the battery voltage with a digital multimeter and found the battery was only showing 10v so I quickly hooked up a battery charger and did a little research. It turns out the alternator on the V8 model is prone to failure.
Unfortunately, it looks like this alternator is specifically made for this engine, the Volvo B8444S which is only used in the Volvo S80, XC90, and Noble M600. Production volume is low, so it's difficult to find a replacement that is reasonably priced. My first call was to the local Volvo dealer to see how much a new one cost. Unsurprisingly it was near $800 for a new alternator from the dealership, and with the additional 3 hours of labor to change it, brings the total cost of swapping out an alternator to a whopping $1300. Not happening.
The stock unit is made by Bosch:
Current output: 180 amps (there is also a 140 and 160 amp model, but the V8′s were only fitted with the 180amp model)
Bosch part number: AL0821X
Volvo OEM part number:
Next stop was to check common online retailers of Volvo OEM and aftermarket parts:
VolvoWholeSaleParts.com - $492.29
SwedishAutoParts.com - $310.00 for aftermarket, $617.78 for OEM, +$75 core charge for both
BuyAutoParts.com - $149.60 + $150 core charge for an aftermarket equivalent, $228.65 + $75 core charge for a rebuilt Bosch OEM, or $361.25 for a brand new Bosch unit
In the end I ordered a rebuilt Bosch alternator from BuyAutoParts.com - they called me a few minutes after my order to confirm that it would fit my car and also to add $75 for the core deposit, which will be refunded when the original bad alternator is returned.
Start by letting the car sit for at least 5 minutes since you took the key out. This allows the ECM to store any running parameters and go into a safe state to disconnect the power. Some impatient or well-meaning garages have damaged or destroyed ECM's by removing the battery cable too quickly after shutting off the engine! Don't take the risk, just go have a drink, use the bathroom, clean the garage, whatever for 5 minutes, then go into the back and disconnect the battery! While the battery is disconnected, hook up a battery charger to the battery. This will be explained below.
Since the V8 powerplant is so crammed in the engine bay, the engineers chose to install the alternator at the bottom behind the passenger side front wheel. The first step is to remove the wheel so you can access the panel and components behind it. Make sure the vehicle is jacked up and on a secure jackstand - you can see the mounting point I used below. After the wheel is off, there are a series of plastic flange nuts that have to be taken off so the lower component cover can be removed. Remove the nuts and then remove the panel.
Here is the refurbished alternator shipped from Bosch - this particular unit was made in Hungary and has the part number AL0821X. Also attached to the alternator is a red tag that explains some warnings about installing the alternator. Interestingly, the warning says to make sure either a brand new battery is installed, or the battery is fully charged before starting the engine with the new alternator. This goes back to the fact that we connected a charger to the battery after disconnecting it from the car, right? You did put a charger on the battery, right? Right? Put a charger on the battery!
Now take a look at the hub assembly - there is an axle nut on the front that needs to be taken off. Remove this, the steering linkage connection, and the swaybar endlink connection to the hub assembly. Spray them down thoroughly with a penetrating lubricant before to make the job easier. The joints may rotate in the socket, so you might need to improvise something to take the nut off. It will also help to jack up the entire hub assembly with a floor jack to make it much easier to remove the swaybar endlink connection to the strut body.
Discussion Starter · #2 ·
With the linkages removed, it's now time to remove the axle from the hub assembly. Make sure the ABS sensor and the brake lines are out of the way - I unbolted the bracket and tucked them away. Turn the hub assembly hard to the left all the way as if you were making a hard left turn - turn it all the way and then get a punch with a blunt point, like a socket and socket extension. Put the punch into where you removed the axle nut and hammer away to remove the axle from the hub assembly. You will need to play with the hub angle and varying the pressure on the axle to get it to pop out.
Before the axle will come out willingly, the axle bearing cradle has to be opened. It's a lot easier than it sounds - follow the axle into the car until you come across a U-shaped piece bolted in at two opposite points. Remove the bolts, and give it a firm whack with a drift and rubber mallet and it will come off. Now, jack up the hub assembly again as if you were removing the swaybar endlink bolt, firmly grab the axle with both hands, and give it a firm tug. The axle will literally pop out of the transaxle. You will need to fidget with the hub and the axle to maneuver it out. You will be able to remove it without removing the lower ball joint, it will just take some time, and some effort to wiggle it out. Remove the jack that's holding up the hub assembly.
See the alternator hidden up there? Before you remove the three bolts, you will need to disconnect the wiring harnesses to the alternator. The alternator output positive cable was easier for me to remove by getting a small 1/4 inch socket wrench from under the car. Reach up from the wheel well, up behind the engine, and up over the alternator and remove the nut that holds the positive cable in and remove it. The alternator field wiring was easier for me to remove from the top of the car - you will need to remove the upper engine mount assembly that goes between the strut towers, the rear plastic engine cover, and the plastic accessory belt cover. Beware - on the accessory belt cover, there are two Torx screws holding it in. With the plastic covers off, you can reach behind the engine from the top of the engine bay, reach the alternator, and disconnect the field wiring.
Now we will need to remove the accessory belt around the alternator. You can do this one of two ways - you can do it from under the car, pull the accessory cable towards you, and put a socket on the crank pulley, and turn the crank pulley clockwise - this will force the belt to rerail over the alternator pulley and pop it off. The recommended way is to get a long socket wrench like a breaker bar, put a 19mm socket on it, and attach that to the welded-on nut on the belt tensioner from the top of the engine bay. You will need to pull on this towards the front of the car firmly for about 40 seconds and slowly the belt tensioner will release and you can slip the belt off the top idler pulley. Take your time on this! If you exceed 177 lb-ft on the tensioner, you can damage it so just do it slowly!
It's just a matter of unbolting the three bolts (two lower, one upper) that hold the alternator to the engine block and dropping it out! This was what took by far the longest for me - it's a tight squeeze to get the alternator out of this little hole you made . Get the alternator out, and turn it around. You need to remove the heatshield on the back of the old alternator and install it on the back of the new alternator, reusing the Torx mounting screws.
Now, you'll need to negotiate the new alternator back into the engine bay and bolt it up. The alternator alone is nearly 20lb - it will be extremely beneficial to have someone hold it while you navigate the mounting bolts in - be very careful not to gouge or strip these threads! The engine block that you are bolting the alternator onto is made of aluminum! Once the alternator is bolted up, install the output positive cable and the field cable - again for me it was easier to do the output positive cable from the bottom, and the field cable from the top. Get yourself a beer, you're halfway done!
Get your 19mm socket and long socket wrench again. Install the alternator belt around all the accessories except the top idler pulley. From the top of the engine bay, put the socket wrench on the tensioer, and give it a firm and steady pull for about 40 seconds to a full minute. The tensioer will release and allow you to slip the belt over the upper idler pulley. I was able to do this with one hand in a few tries, but it would probably be easier to do with a helper. Again, do not exceed 177 lb-ft on the tensioer pre-loading bolt!
Now, jack up the hub assembly again and install the axle back into the transaxle - putting it back in required some wiggling of the axle, the hub assembly, and adjusting the height with the jack. Make sure the bearing surface is clean and then bolt the bearing cradle back up. Now comes the tricky part - turn the hub assembly to the hard left again and get a long prybar or long thick screwdriver and brace it against the lower A-arm, and the other end near the ABS sensor teeth. With enough careful prying, and fine adjustments with a large hammer, you CAN get the axle back into the hub assembly without removing the lower ball joint. Trust me on this, it is possible. I had no tools available to remove the lower ball joint so this was the only option I had!
With the axle back in place and the hub assembly still jacked up, connect the swaybar endlink back to the strut housting and lower the hub assembly. Reinstall the axle bolt and the steering linkage. I found I didn't need to hold the center bolt section on tightening. Re-install the ABS sensor line and brake line brackets.
Now, clean off the engine bay and reconnect the battery. Double check that the belt is installed correctly and the alternator is wired correctly, and the engine bay is free and clear of tools, rags, and foreign objects. Start the car and check the voltage across the positive junction and a ground - you should get above 14 volts now! I was able to get 14.29 volts. Yay! The alternator works! Shut off the engine before it gets warm so you can work in the engine bay without getting burned and so the radiator fan doesn't run continuously. You can now install the wheel, the accessory belt cover, the rear engine cover, and the upper engine mount. Pat yourself on the back well done, and soak in the feeling that you didn't have to pay Volvo over $1000 to fix the car. Enjoy! The fact that you disconnected the battery cable will clear any CEL/MIL.
Newbie here, but read these posts for information about my car frequently.
I bought my first Volvo, an 05 XC90 V8 last fall, with 128,000 miles on it. I've had to do a few things to it, but all routine maintenance type items. Really really like this car so far.
Last Monday, after a 600 mile trip and about 5 miles from home my stereo cut out abruptly and I got the Power System Service Urgent message and the battery icon. I made it home and checked the battery while running to see if the alternator was working, but the voltage was right around 12. I did the usual Google to see what that code means. Saw that most of these faults were fixed with a new alternator. With 138,000 on the clock, I figured that it could use one even if that is not the problem. I ordered a AL0821X Bosch unit from FCPEuro and had it dropped shipped to my Indy mechanic. It looked like there have been problems with "other" alternators for this car, so I wanted the genuine article. I printed this how-to guide off for him, since there were some watchouts that could easily be missed otherwise. He had it changed on Friday, but the error remains, and it appears that the alternator is still not charging. This is my only vehicle and I'm getting worried about the bill and getting tired of creatively trying to get to and from work.
I guess I'm looking for any info about possible bad rebuilt units, or if it could have blown a fuse of some sort. I was able to eject a CD after the incident, so not so sure about the fuse thing. My mechanic uses Alldata, but I read somewhere that it's not very good for Volvos.
Any input here is appreciated. Thanks!
It's true that AllData (either PRO or DIY) is seriously lacking in a lot of Euro applications such as Volvo.
The alternator is controlled by the PCM so you should check the field cable that goes the the alternator. If that cable is broken or has a bad connection, it can't control the alternator. It requires starting the car and hooking up a multimeter to the field cable to check for a signal. You can also bring both your old and new alternator to Autozone or one of those type of shops. A lot of places will test alternators to see if the alternator itself is bad. I would start with that to make sure both alternators, then go back and check the field cable in the car. If that works as well, I'm afraid I'm out of suggestions.
sub'd
For information, if one wants to subscribe to a thread, it's as simple as using the "Thread Tools" drop-down on the top bar below to the right of the thread subject line. Select "Subscribe to this Thread".
Keeps things clean rather than having these old threads go back to the front of the queue. Not everyone wants to read them again.
Well, I'll be damned! Thank you!
Add me to the list. I thought the frequent warning could be caused by the belt, but last night proved otherwise. We made it home, but the battery is now also dead. Ugh... This '08 is turning out to be a pure headache.
I've never experienced a dying alternator like this. It started throwing one warning message after another, disabling airbags, stability control, headlight failure warning, and all sorts of odd things. It was truly a Christmas tree of lights and triangles.
I know what my weekend will look like... ugh.
Just wanted to say thanks. My alternator died a few days ago. This AM, thanks to your excellent write-up, I removed the old alternator without too much trouble. :D
i dont read instructions, but i was told on youtube this was a 5 hrs job and dealer charges 3 hrs...so you know you can do it in half the time then , right? ...lol...35 min to remove and 50 min to install...this is all i removed...i put there a used Bosch 180 amp from ebay 70$ shipped :D
dougy, that is truly impressive! did you need to prop the engine up by any means? and I bet your rear engine mount is all taut and in good condition?
No...the mounts look like they were replaced at some point... the hardest part was loosening up the Plus wire coming into alternator which I waited till I loosen he alternator first from the bottom... and wiggling the alternator out and wiggling it back and then holding it up with one hand while trying to get the first bolt holding the alternator in to line up.... what you see in the picture is all I had to remove plus the axle.
i came up with a fix to reduce heat / move heat instead of keeping it in with the undercarriage shield mod...
here is just the for the alternator / if you are conservative.
and here is if you want the air to move from alternator , engine and trans.
Those triangular shapes molded into the shield look a lot like NACA air ducts. You want air flow in through the grill and out through the gap at the back of the shield near the firewall. Consider the possibility that under the front of the car could be a high pressure area and changing the shape and coverage of the shield only prevents the hot air from exiting out the back...
Maybe not, I don't know. Would take a wind tunnel to be certain.
I'm just a lowly aircraft mechanic. All I know is if you cut a hole in the bottom of an engine nacelle to "let air out" you'll reduce the ram air exiting the cowl and the engine will overheat. And we don't have to deal with the air being trapped between the nacelle and the ground for very long. The boat shaped front end of the XC90 is definitely compressing air under the front bumper. The ducts in the shield are probably creating localized low pressure areas from the velocity of the air flow to help extract air from the engine compartment.
1 - 20 of 36 Posts
