1 - 12 of 12 Posts
Has anyone upgraded these pieces and worked? I looked at the numbers on the stalks and tried to match them up with newer ones and of course the numbers don’t match. I’m thinking as long as the functions match it may work. Just want to make sure before I buy a wiper stalk without automatic wipers.
CAN is different you’d have to transplant all the guts. Not sure it’s been done successfully. If you traced the wires and it was all the same hardware wise then maybe?
I would try it if I had a good idea of how they came apart. I might have some tinkering to do...
Stalk has wires coming to a board
Base clips together
Everything works with swapping the board over except for the mpg screen and others. It will read through messages but will not cycle through the regular positions on the dim
I’ll get a stalk out of the junkyard that would match my car and I’ll disassemble it. The older ones come apart different than the newer ones. The newer ones have screws on the back to pop the cover off vs the older ones don’t. I’ll dissect a older unit and take the reset/read and toggle board out of it and put it in this one.
This is the board that would need to be changed
Newer stalk
Older stalk
I think it’s doable, just some time and tinkering. The windshield wiper stalk should be a simple swapping of the board.
Newer stalk
Older stalk
Cool. Looking forward to seeing what you figure out!
that's a lot of work for a stupid piece of trim.
1 - 12 of 12 Posts
