1 - 10 of 10 Posts
is it possible to just bolt on a bigger turbo to my 04 2.5t awd s60? i know im in danger of blowing some parts if i turn up the psi too much. Is there a type of turbo that i can directly bolt on and have no problems?
Re: turbo upgrade (liquidforce1887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>liquidforce1887</b> »</i></TD></TR><TR><TD CLASS="quote">is it possible to just bolt on a bigger turbo to my 04 2.5t awd s60? i know im in danger of blowing some parts if i turn up the psi too much. Is there a type of turbo that i can directly bolt on and have no problems?</TD></TR></TABLE><p>Very few people are doing turbo upgrades. Get a "chip tune" from BSR or IPD if you're looking for the next step.
Re: (liquidforce1887)
The problem is, you'll need a chiptune to utilize the new turbo anyone. If all you do is put on new hardware, the ECU will still only "allow" the same boost as stock. You can't just stick a Boost Controller on these cars, the computer will go into limp mode.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>liquidforce1887</b> »</i></TD></TR><TR><TD CLASS="quote">i would, but i dont have the money. i can get a good turbo for 5 or 600.</TD></TR></TABLE><p>as someone said in a different thread..."you gotta pay to play"<p>its a volvo...don't take shortcuts
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">as someone said in a different thread..."you gotta pay to play" its a volvo...don't take shortcuts</TD></TR></TABLE><p>indeed, that was me. the bottom line is, you usually get what you pay for. if you want or need something enough, it's easy to justify or rationalize the cost. as long as you get utility out of it, then no worries...enjoy the toy! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
if your going to spend money to get a decent gain from a bigger/better suited turbo, ur gonna have to do pretty much upgrade everything else too. Fuel's going to be upgraded: injectors, fuel pump. A tune's def going to be needed, including dynos. and if you have AWD...good luck finding an AWD dyno in michigan. if the turbo's adding that much of a boost, pistons/rods/blueprinting/sleeving is going to be needed to not compromise the reliability of the engine. If this was a ricer integra(which i used to drive in college pos imho but did the job)or civic, then boost away, b16/b18's are plentiful, ours are not. as said before, it's a volvo...don't take shortcuts
yeah, i know im pretty much f'ed. i dont have the money for any of that, but on the bright side, theres a garage that has an AWD dyno four miles from my house.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>liquidforce1887</b> »</i></TD></TR><TR><TD CLASS="quote">yeah, i know im pretty much f'ed. i dont have the money for any of that, but on the bright side, theres a garage that has an AWD dyno four miles from my house.</TD></TR></TABLE><p>Just wait until you can afford the $895 BSR PPC (from engstrom) and get that. It will make a very noticeable improvement, especially since you already have intake/exhaust.
1 - 10 of 10 Posts
