1 - 10 of 10 Posts
Is it normal to have a little play on the exhuast side of the turbo?I had the DP off today and grabbed the compressor wheel and it had a little play is this normal?
milage ?
and you should have no play ...
Re: (Chilled Man)
22K miles it wiggles just a little but it is noticable.It's on my 07
if under warrenty take it in and see what they say .
there shouldnt be any shaft play in a turbo that age.
shoot the one I got form Ski-R with 50k on it has none
Re: (Chilled Man)
Ehh dealer here probably won't do anything anyways probably have fun explaining why I was even in the turbo.They are not mod friendly at all.
Re: Turbo shaft play (volvosince16)
Quote, originally posted by volvosince16 »
turbine wheel ; )
minimal shaft play is fine as long as it isn't in and out, rather up and down
and by minimal i mean not a lot at all, hard to judge, but there will be a little play
Re: Turbo shaft play (TurboR850)
Thats what it is up and down movment just enough to notice,no in or out movement.
Its fine, wouldn't worry about it. . . .
loose shaft would cause gasket / seal wear and cause oil consumption.
But a turob car will use a little oil anyhow .
1 - 10 of 10 Posts
