1 - 20 of 25 Posts
hi, does anybody know Whats the name of the little tube that goes from the turbo to the engine, its screwed to the turbo with 2 torx screws.
My turbo is leaking there and I would like to know if there is a gasket for that part?
no pic as of now, sorry
Im sesrching on tascaparts but i dont see a upper gasket nor a lower gasket
Thank you, sir!
I'm going to have to make a video but after installing the IPD TCV you can a very loud rush of air escaping from the turbo somewhere and was hoping it was this gasket.
It wouldn't be from the oil drain. That's your waste gate or CBV. Have you checked for leaks? It sounds like hose off although even a hose off wouldn't make a loud noise. If you're intake hose was off it would run poorly.
I did check for leaks with just a spray bottle with soap/water. I finally hooked up my boost gauge and I'm getting literally ZERO boost pressure in 1st and 2nd gear and 3rd gear and so on if I hammer down the boost will go up 15psi for a second and then go to 3-4psi. Can it be a defective TCV? I'm going to make a video next week when I have some time.
Discussion Starter · #13 ·
Pczeilon thank you very much
I'd say you have it plumbed in wrongly. Check the lines are in the right place first of all.
Discussion Starter · #16 ·
Part 21 (PN): 986214
M6x16
What kind of torx bit does this use, or this is it some sort of euro size?
This simply states that the bolt has a 6mm shaft 16mm in length. It gives no information about head size, type nor thread pitch.
That said, someone on here with a turbo probably knows the answer to what you are asking. ;)
Discussion Starter · #18 ·
Oh ok, thanks. Anyone?
1 - 20 of 25 Posts
