A read car will not know you bolted anything on. It's pretty much to get your software version so RICA can give you a compatible program.
I asked Frank (EST) a similar question... If you have the RICA tune for having a downpipe, that's all there is unless you do a custom map. Custom maps require a dyno run logging all parameters (speed, rpm, boost, a/f, dunno what else).
Found the email reply from Frank:
"Adding an intercooler normally does not require different software. Custom software can also be created if you dyno the car and send us all of the log parameters that we require to make adjustments to the program."
