Alright, situation is as follows:
The car is a 1999 V70 AWD 2.5LPT manual, as we speak running with the stock 13T. The past year or so I feel I've gotten it back to a decent stage 0, the only thing I know remains is a slight oil leak, seemingly from the turbo. There's little or no PCV gunk in the intake, but always oil on the compressor outlet when I remove the pressure pipe. Whether or not this is flowback from oil vapor otherwise going through the combustion process is unknown to me, but I have a small and controllable oil consumption, thinking turbo seals. The turbo has been with the car all of its 234k miles, so I guess it's not unexpected.
So, time to change. I have a 16T angled outlet which is getting a rebuild in a couple of weeks, I'm getting a new cat and 3" downpipe, and thats all I intend to do partswise. My closest tuner I am wiling to consider either deliver ready to use PPC-units (ME7 uploader with software) designed to replace OEM software, and this does not take different turbo and downpipe into consideration. Only other alternative is a full on dyno remap. Price almost doubles.
I'm not looking for a monstrousity regarding power output, just ti utlize the improvements on the engine a best I can. I know ARD lets you custom select what upgrades you have made mechanically, will they do the same for LPTs, and customize it to the 16T with DP?
Will they ship to Norway? Do they supply the upload interface, or will I have to make something myself? Any other recommendations in tuners?
And being a relative turbo n00b, what spec wastegate would you reccommend? The 16T came off a T5 with half the mileage of mine, and the wastegate seems to be in working order... but better safe than sorry, or worse... without boost. Appreciate any replies.
