Must be having a senior moment. I am fairly certain that I remember applying a light coat of dialectric grease to all of the contact points of the rotor(blade-end and spring contact) and inside the distributor cap when installing new components. Yes? No?
Well I did, and now the car has a very slight shudder. But, I also have a hole? in the coil wire (outside sheathing and outside braid). So, while waiting for a new coil wire, do I need to go through and clean off the dialectric grease, or should that be ok.
Thanks
Thanks
