1 - 20 of 31 Posts
On my drive to the gym last night I stopped to fuel up. Leaving the station I made a 45 degree left turn and accelerated into the lane. I felt and heard a big clunk (like if you were running over a box of shoes) and immediately something was not right. I had no lights on the dash and the car felt fine, at this point I was babying it to the gym. Getting off the highway about a mile later I realized something was not right, particularly when taking a hard left or right at slow speeds and feeling like my wheel was loose and about to fall off (my initial thought). Drove home and today I replaced the drivers axle shaft with the same noise and feel at slow speeds with the wheel turned left or right almost full lock. I put the car up in the air and did some tests but was confused when the back wheels weren't spinning? Aren't the rears supposed to spin when there is no traction up front? I also heard this noise that only happened when the car was up in the air. At this point, I'm pretty lost on to what the culprit to the problem could be. In park off the ground, both front wheels and rears spun freely which I don't think is right. Driveshaft is not loose or have wiggle room around angle gear. But slowly turns when the car is in drive and idling however the rear wheels don't move at all. VIDA shows nothing and no faults. I got this car with 68k and have done two transmission flushes since (105k now), transmission has no issues. I've topped off TC with gear fluid around 80k miles. I did have an issue with my AWD module that I replaced and filled with correct level fluid (or so I think). I will be checking fluid levels tomorrow. Any thoughts on what's going on? I did take some quick videos to help share an idea of what's going on.
https://www.youtube.com/watch?v=bsDKwMFShnw
https://www.youtube.com/watch?v=EZywzkJMylY
https://www.youtube.com/watch?v=TCrCOlJIdQM
https://www.youtube.com/watch?v=QhfaO3Gx-ek
Your collar sleeve broke. If it's the first one, your transfer case has enough of teeth left for the replacement collar sleeve, which is like $145 in parts. It will buy you another few years, then it will strip again and then you'll need a replacement transfer case ($1500). At that point you may get rid of car or buy a used transfer case with good teeth.
Or you can attach the collar sleeve to the transfer case's input shaft with the weld seams, or something along that way.
The reason of why "something is not right" is a tremendous torque steer effect that turbo AWD car has when it looses the rear axle traction unexpectedly. The ECM expects the rear axle to kick in via Haldex and take care of torque distribution, so it does not limit engine's power beyond of what AW55 asks for in first two gears, which is still like 180 ft lbs. Almost the same setup - S60/V70 turbo, but FWD by design, and it does it right from the standstill. In FWD XC70 you better keep the steering wheel with your both hands :)
Thanks for the information. Just what I needed, another project.
I may be wrong, but that doesn't sound right to me. If his collar sleeve stripped out then wouldn't the driveshaft not move? Easy test (that I know of) for collar sleeve is if you can spin the shaft by hand with the wheels on the ground, then the sleeve is stripped.
If that's not the case, then would suspect a haldex issue.
I could just be reading it wrong but the way I'm understanding it, it doesn't sound right to me.
EDIT: Nevermind. Watched the videos and I see now. Should probably stop driving it like that before you grind off what's left of the teeth. That noise makes me cringe .
The AWD traction system is based on the info pouring in from the 4 wheel speed sensors. You can't really fully test the rear wheel drive by jacking up the car off the ground...the 4 wheels rotate at the same speed, with almost no torque load, and with 90% of torque delivered to the fronts. If the rear wheels fail to turn at all, that would indicate 100% loss of torque somewhere between the angle gear, prop shaft and Haldex.
A better test of the rear wheel power response is to stop with the front wheels on a low-traction surface (ice, wet cardboard) and the rears on good traction surface. As you accelerate fwd, the front wheels lose traction and spin faster than the rear wheels...the computer responds to this difference by engaging the Haldex clutch, transferring up to 50% of torque to the rear wheels. If its working you should begin rolling forward despite the front wheel slippage.
Are you getting any ABS warning messages? If a wheel sensor is going bad, the computer reports an "ABS System Needs Service" alert to the console. VIDA scan will pinpoint the errant wheel sensor.
A shot wheel sensor can trick the ABS system into pulsing the brakes in bursts, which makes a "thump, thump" sound and gyration. Your "driving over a shoebox" reminded me of that experience.
In Park, the front wheels should be locked by the pawl in the tranny. You're either not really in P (gear shift switch assy. problem), or the pawl has been severed off...you would then have a chunk of steel lying in the bottom of the tranny (the pawl pin). When you changed the tranny fluid, did you look for metal chaff?
Discussion Starter · #9 · (Edited)
No messages on dash or VIDA of any kind, that's what puzzles me. By a wheel sensor, do you mean the abs sensors on the knuckle on each corner? The "thump, thump" sound is exactly what I heard, however no lights on the dash. Making a sharp turn say from a stop sign if felt like the front wheel was "wobbling" and about to fall off. That's what initially led me to think an axle shaft.
To answer your second comment, I haven't changed trans fluid since, I just stated that before to indicate the trans should be in good shape as I believe I take decent care of it (ie dont drive it too hard, I know the trans doesn't like getting hot). The wheels were free spinning with the car in park with the car jacked up off the ground.
Is that the noise of the collar sleeve stripped? I really need to put the car on the lift to see if driveshaft moves on its own, but it didn't seem to budge when I reached under and tried to get a grip.
Yes. And it's a death spiral for the transfer case: you may replace collar sleeve one or two more times, but it will be stripping quicker and quicker.
Yeah. You can see it's got just enough purchase to grip a little bit but once the haldex applies a load, it slips and grinds.
Otherwise, a failure of that type will not cause any codes AFAIK. Most of us with P2's have been through this, including myself, and never had any codes or warning lights. AWD just stopped working. Which is a bit of an oxymoron...because technically the haldex is working properly. It's just not getting turning force form the driveshaft. Which it doesn't know.
Discussion Starter · #13 ·
I appreciate the feedback. I have been reading threads and getting that sleeve out looks like a 10 hour fight.
Discussion Starter · #14 ·
I have used my AWD all of twice with this car. If this car would last another 3 years I will be happy, which sounds like the lifespan of the new collar sleeve I'll be installing, and then i'll move into something newer or FWD.
It took me maybe 5 minutes with this kit: https://www.amazon.com/Bearing-Puller-Internal-Extractor-Remove/dp/B017XDLDDY
Taking out passenger axle can be challenging the first time, however it is possible to take it out without fully disassembling the strut/wheel hub.
Get a long torx set for the propeller shaft bolt, and a few extensions.
I would not say it is super-hard. Definitely not 10 hours, maybe 2, including consuming couple of beers.
I mean...you could run it FWD with no issues. I remember when mine broke on my S60R. I was parked and it had snowed the night before. So when I went to drive out of my spot the wheels spun a little bit and as soon as the haldex grabbed the collar sleeve stripped. I didn't know what it was at the time. There was just a clunk like a stuck brake pad. Which happens sometimes with the snow and salt....rotors rust quickly here. But yeah, it turned out to be that. I honestly didn't even notice because I had blizzaks on the car for winter anyway. I went through the rest of the winter with no idea there was anything wrong.
It always seemed to me that the manual transmission cars were more prone to this type of failure than automatics. Mine was a manual. My XC has almost 240k miles on it and it's fine...but IDK if the collar sleeve has ever been replaced before. My car isn't haldex though.
Overall it's just a poor design. I think Volvo did make a revised collar over the years but idk. There's also that guy who sells hardened steel ones. Some people just weld them as well.
Visco coupler does not wind up like Haldex does, so it rarely if ever strips the collar sleeve.
Discussion Starter · #18 ·
Not concerned with the axle shaft, I've done plenty. And luckily I have a lift. I will definitely be looking at getting a tool like this before I tear into the car - thanks for the link.
Discussion Starter · #20 ·
I think I'm just going to fix it, Im not too intimidated by it besides pulling the collar sleeve out. I just need this car to last me through college and then any more miles I get out of it will be gravy.
1 - 20 of 31 Posts
