True "plug-and-play" P1 HID conversion
12K views 23 replies 10 participants last post by  carreragt7
#1 · (Edited)
Edit (2017): If you found this via Google, the information in this thread is vastly out of date. Please see this thread or skbowe.com for current information on BOW and WMM failures. The process below still applies to the physical conversion, but you do need to consider the electrical ramifications regardless of using OEM or aftermarket ballasts
I'm helping out with a project that is, IMHO, a major step forward for the P1 community. Until now AFAIK there have been only two categories of HID conversions for P1 cars with halogen low beams: (1) Traditional retrofits, where you shove a H11 re-based bulb into the halogen projector, and (2) projector retrofits, where you find some other european car with the correct size/shape projector and bolt it into your existing housing. Neither of these routes are optimal since both require extensive modification to the housings.
So someone got the idea to take the *entire* bi-xenon housing and completely replace the halogen housing. If they had asked me first I would have said, "It won't work because you need a new engine harness and have to reprogram the ECM to talk to the GDL modules over LIN, plus install all the auto-leveling sensors and that's at least $2500 right there." But fortunately, I wasn't asked, and it turns out that I am (completely) wrong.
In fact, contrary to the wiring diagram that's been on my website for the last few years, the OEM bi-xenon housings are almost completely plug-and-play, with the exception of exactly one +12v wire which isn't in the halogen harness EDIT: AND THE PWM Voltage Regulation in the Halogen CEM I've assembled a corrected wiring diagram here. Granted, the auto-leveling and road-following won't work (that's a project for another day :cool: ) but everything else, including the OEM ballast, does.
The headlight assembly that will be used in this writeup was removed from wreck, so is pretty well banged up, including a broken ball joint and a cracked lens. So the first step will be to fix that stuff.
Started by stripping everything out of the assembly so I could actually get to where the ball joint failed. This required baking the housing at 250 degrees (F) for 15 minutes to loosen the butyl rubber weather sealant around the lens. Next the reflectors were removed one by one, and finally the optics tray was extracted through the front. The resulting shell is rather disparaging. Excuse the iPhone pics:
</img>
You can see (sort of) where the ball fell off. If you can't spot it, look for the laser:
</img>
Here's the ball. It was supported by a piece of plastic that I had to cut away, and of course the resulting knurled shaft doesn't fit in the hole:
</img>
There is a lot of load on this piece, so I had to come up with something that had actual structural integrity. How about a screw?
</img>
Now how to get the screw to support the ball joint that was previously cast in plastic? Drill and tap anyone:
</img>
Hopefully you can see where this is going
</img>
Of course, never one to leave well enough alone I found some alloy tubing with an ID appropriate to press fit over the ball joint shaft and the screw.
</img>
The outside of the alloy tube got roughed up a bit, then pre-heated and melted into the housing. Before the ball is screwed in...
</img>
Industrial size JB weld. There's enough JB weld in there to put the Titanic back together, and still have enough left over for this project. While the JB weld is setting, I thought I'd test out the electronics.
</img>
Note that the bulb is a D1S, which is the same base as an D2S but includes an integrated ignitor. This means that an aftermarket kit with D2S bulbs will work just fine. Seems like it works to me:
</img>
An interesting note is that while the ballast is labeled 35W, it draws around 4A (which is around 45W or 50W) - much closer to 55 than I expected. It's possible that the bi-xenon cars use the same bulb-failure circuitry in the CEM.
Stay tuned folks, this is gonna get interesting. :D
this is great! i rather do a retrofit than buy a kit that might fail on me.
Nice work, going to be awesome when its done. Upgrading to a true xenon projector is a night and day difference, just a side by side comparison you can see how differently the bulb sits in the projector. Bout as close to a factory xenon kit as your gonna find, making good strides this year seems like haha.
I looked at this last year.
Here's my thread - http://www.volvoforums.org.uk/showthread.php?t=105986
In the end rather than trying to buy OEM ballasts etc, I just went for my existing after-market HID kit and installed using a D2S to H11 adapter cable.
But I agree, all the wiring is the same except the single pin and what you can do is link the 2 wire/single solenoid on the dipped beam to the main beam circuit.
I have three of the Bi-Xenon lamps in my garage now as I have been rushing through the face-lift body panels.
I did have them running briefly to test the circuitry and all was fine, I think I added pics in my thread too.
Good luck and let me know how you get on :)
Jason.
Sounds like my room. I've had like 4 sets of lights sitting there for over a year, LOL. Way too many extra parts in my apartment, not enough time to play with them all.
Thanks for the extra info JasonB.
Keep up the good work Jacob!
#8 · (Edited)
Nice Stuff - Man - Keep the Great Write Up going It will become a sticky .
I just used up the last of My JB Weld on the back of a Dryer the 220 mount had broken during a move - Condensing 2 house holds into 1 - just sold that set .
I find using Goof Off after scuffing up the mating surfaces - really gets that stuff to Bite & Hold On .
owns 2009 VOLVO V70 3.2S
#9 · (Edited)
Finished the ball joint repair. It ended up taking three layers of fiberglass reinforced JB weld before I was satisfied. Each layer was allowed to cure for 24 hours then sanded for better adhesion. It's pretty solid.
First coat of JB weld:
</img>
Here's the second layer:
</img>
Third layer, with optics tray in place:
</img>
Compare to the reference light (this one isn't broken). Note that it's the other side, so the image is mirrored horizontally:
</img>
If you overlay the images you can see how close it is:
</img>
Starting to look more like a headlight...
</img>
#12 ·
All that initial work was because of this,
"The headlight assembly that will be used in this writeup was removed from wreck, so is pretty well banged up, including a broken ball joint and a cracked lens. So the first step will be to fix that stuff. "
#14 ·
Shadow - looking forward to the How-to writeup! thanks for the time spent on this!!!
So will the final product be rewired bixenon headlights that plug and play into a stock halogen vehicle? That would be sick aside from the price of xenon lights.
#17 ·
If I'm right, which I'd give a 98% to right now, then the final product will be a (literally) plug-in unit on the inside of the headlight that allows it to plug into the halogen harness just like the halogen light. It will take a few special connectors (4 pin male/female Molex minifit - same as the 4 pin power connector on computer motherboard) but zero wire cutting. Only downside is no auto-leveling or road-following, but that's a much harder project.
BTW, for those with the OE bi-xenon who want to use aftermarket bulbs/ballasts, I might try to fab a cover that has a built in mount for the "slim" style to eliminate drilling holes. Still TBD on that though ;) Would be nice to find a company with manufacturing capabilities to crank these out...
#18 ·
It's possible. Depot came out with black housing type R style projector headlights for the rsx community that were considered better than oem quality.
#20 ·
Dead link, but I have the official diagram, and it is wrong.
#22 ·
Your link doesn't actually show up in the thread, but it did show up in the notification email.
#23 ·
The second part of the repair, the cracked lens, was a bit more difficult. Luckily while I was cleaning out the old butyl I was able to make the obligatory sacrifice to the automotive gods
</img>
which gave the rest of the project a pretty good chance of success.
Before the pictures start, background. The P1 headlights use a plastic lens sealed with butyl rubber to an FRP housing. The lens is optical grade, UV stabilized, polycarbonate approximately 1.5mm thick, which is ultrasonically bonded to a black acrylic mounting flange around the perimeter. The ABS housing has a channel which accepts this flange, and it is clamped in place by four metal clips.
In the lens below, the crack started at the edge (which is still polycarbonate) and propagated down about 1.5cm through the polycarbonate lens, and completely through the acrylic flange. Left alone, the crack would not only leak water, but almost certainly spread further down the lens. The worst part of it though is that at the crack, the acrylic and polycarbonate weld fractured, leaving an ugly white streak down the black perimeter.
Fixing something like this is not straight forward:
1) excavate the area around the crack to solid material which is well-bonded, that is, cut about 2mm on either side of the crack tapering down.
2) polish the transparent portion of the excavation to maintain optical integrity
3) reenforce the mounting flange around the crack with a stronger material to give it structural integrity
4) fill removed polycarbonate with optical grade epoxy
5) fill removed acrylic with black epoxy
6) fill the reenforced area of the mounting flange with a strong epoxy
Given the quality of the camera on my two year old iPhone, photographing the procedure has been equally challenging. I've picked a few of the best of the pictures&#8230;
Step 1 - Here's the best one I got of the initial excavation. It's kinda like snow white in a snow storm, but use your imagination :p
</img>
Step 2 - Here's it polished. Again, it's hard to tell the difference from the pics. Visually, it's the difference between the area around the crack being clear vs opaque.
</img>
Step 3 - Reenforced with some kevlar I had lying around. Thread was crisscrossed through 8 holes, tightened, and superglue-knotted. Rinse and repeat. Twice. After this point, putting pressure on either side of the crack no longer causes it to flex open.
</img>
Step 4 - Here's the optical grade epoxy poured in. This took 48 hours to cure completely since it's 1 hour working time to start with (regular epoxy is 5 minute) and had to be refrigerated (otherwise it sets too quickly and turns brown).
</img>
Step 5 - After the clear epoxy set, I roughed up the surrounding area, masked off stuff, and poured the black epoxy:
</img>
and after another 48, cured:
</img>
Step 6 - Break out the JB weld again, it's the strongest stuff I know of. I'm holding the test shots from the other two epoxies so you can see what they look like, it's really hard to tell from the pics
</img>
And there you have it, the black is not a perfect match (actually too dark&#8230;) but it's waterproof, stronger than the original, and almost invisible from a distance because the original lens surface is maintained.
</img>
(I think it's getting covered with vinyl anyway, so waterproof is the important part ;)
Next up is reassembly&#8230; luckily new butyl is a lot nicer to work with than baked on old butyl so it shouldn't be too bad.
