can someone ID this #0442 code please!<br>thanx <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: trouble code (volvoom1)
Sure! <A HREF="http://www.codereader.com" TARGET="_blank">http://www.codereader.com</A>
Yeah, check your smaller hoses...especially those that enter under the intake manifold on each side. The one under the power steering reservoir with the 90degree elbow is prone to failure. You can spray some carb cleaner on it while your engine is running...if you get a surge, you'll know you've found your leak. If nothing there, try the other side and the vacuum hose tower under the throttle cover. Good luck! <p>Then again, it could be as simple as a loose gas cap...make sure it gets several clicks when you tighten it after a fill-up. <BR><BR>
<i>Modified by MadeInJapan at 10:38 PM 8-2-2006</i>
