1 - 6 of 6 Posts
My 98 has no factory trip computer installed, how ever when I installed my new R cluster it is present to me. That the car it was off had a trip comp. do I just need to install all the switches to have a trip computer or what? Anything else I need? Should I just leave it alone? Thank you.
It is possible. You just need to switch that goes in the dash and the wiring. If you can find it in a car at a junk yard, that would work. Then the part that can be hard to swallow. There is software that is done at the dealer. The part number is 9438259 I believe and usually costs around $190-$240 depending on the dealer. That software will link it and give you all the functions of the trip computer.
I dont know if this would work, but I have an ECU from a 98V70T5 that had a trip computer. Seems to me if you use that, you wouldn't have to visit the dealer....
pm if interested
No software in 1998
So when I plugged in my new dash it said no disc upon driving it. So I pulled the switch fromy xc and the trip comp works, I'm just finding impossible to get to the light in the switch as it stands out with my led swap.
pm if interested
I already was running a 98 v70r ecu so if that was the case I think my ecu would have done it. Is there a 98v70r without a trip comp?
1 - 6 of 6 Posts
