1 - 11 of 11 Posts
I was on the freeway this morning running about 60mph and pulled up behind a transport who had just turned on his 4-ways. I pulled out to pass, but not knowing what was around him I did not kick-down, but really only tapped the accelerator during the lane change.<p>It was during that tap that the car clunked/jerked. It just felt (in my best NASCAR drawl) like somethin' broke. The transport had put on his 4-ways due to a major slow-down in the trafic about 1/2 mile ahead, which gave me time to look at the dash; 'Transmission Service - Urgent', and the engine light. Great.<p>My destination had an auto service centre near by, so I had them take a look. They could not read the codes, but did inform me that I had no 1st, 4th or reverse gears. They were able to let me know that 50-40LE and 50-42LE transmissions are known to exhibit a No Reverse, No 1st, No 4th condition before or after an overhaul, and the culprit may be the solenoid screens being installed upside down on reassembly after an overhaul blocking the solenoid feed to the shift solenoids and shift shift valves, or that the shift solenoids are not functioning mechanically.<p>I was able to limp it home to my dealer (I think the only thing that didn't pass me was people on bicycles - and even them only barely), where it sits now. They will not be able to look at it until tomorrow as I only managed to get it in shortly before they closed.<p>It will be interesting to see if they come back with a 'reasonable' repair estimate or if they tell me I need a new transmission.<p>I'll keep you posted...
Wow, so you have no idea what caused this? eh.. makes me nervous about my "steptronic" tranny... Goodluc....<p>P.S. your photos are excellent!
Re: (Copeland)
The dealer had the car all day and at 3:30 finally told me....I need a new transmission at $4200 plus tax. The ensuing conversation went something like this:<p>Me: "What's wrong with the transmission that's currently in the car?" <br>Service Advisor: "Um, I'm not sure."<br>Me: "Yet I need a new one? Perhaps it would be a good idea to find out what's wrong with it before telling me I need to give you close to $5000 for a new one."<br>Service Advisor: "Um, I'll speak to the technician and call you back."<p>Realize I had mentioned the known solenoid issue when I brough the car in yesterday. <p>Two and a half hours later I called him again and was told that (curiously) they'll be looking at the solenoids on Monday, but to do so they'll need to drop the transmission. At the end of the day if it turns out that I do require a new transmission, so be it (though if that is the case I will be placing a call to Volvo to see if I can get any relief - the car's only over the waranteed limit by 6200 miles (10000 kms)), but don't just tell me a new transmission is required when you don't even know what's wrong with it........<p>--Thanks for the kudos on the pictures.
Re: (Muskoka)
Update:<p>What a waste of two days. After telling me on Friday that they'd be dropping the transmission and opening it up to see what is actually wrong with it today, the service advisor called me this morning to tell me...I need a new transmission. They are still basing this only on the codes, but have not, as I was told would happen Friday, actually done anything to see what's wrong with it.<p>I called a 20-year independent Volvo-only shop (I didn't take it there in the first place because they were closed by the timeI got back into the city last Thursday), who didn't have a replacement transmission in stock but rather referred me to the automatic transmission shop they use for re-builds. He also told me that he has never had a transmission rebuilt by this shop come back with a problem. The transmission shop went to the Volvo dealer, picked up my car, took it to their shop and quoted me $2600 for a full rebuild complete with new solenoids and upgraded valve bodies.<p>It'll be ready Wednesday.
Re: (99S80man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>99S80man</b> »</i></TD></TR><TR><TD CLASS="quote">you mean ford?</TD></TR></TABLE><p>I assume you're referring to Majisto's post? No, he doesn't mean Ford. It's a GM transmission.
Re: (Muskoka)
Oh this makes me very very nervous. Im about to be the owner of a 2001 T6 with the geartronic of course... it has 94K. I wonder what percentage of owners of this model have problems. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: (TurboMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>TurboMoose</b> »</i></TD></TR><TR><TD CLASS="quote">Oh this makes me very very nervous. Im about to be the owner of a 2001 T6 with the geartronic of course... it has 94K. I wonder what percentage of owners of this model have problems. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> </TD></TR></TABLE><p>i have 106K 2001 T6 and wail on it. just keep your fluid changed regularly. i actually put hi-perf fluid. forget the brand, my mech does it. i'll find out. i just had it power flushed as well.
Re: (SkyWriter)
Ultimately what did my transmission in was a failed planetary gear. One of the three appeared to have developed a crack and when it actually let go, it sent pieces into the remaining gears.<p>I do not regret buying the car depite this failure.
Re: (Muskoka)
Well this is something that can just happen. It doesnt seem like this would be something that would happen on many other transmissions. Im starting to believe the T6 GearTronic is actually a pretty reliable transmission.
1 - 11 of 11 Posts
