So I have had this "issue" for as long as I can remember.
When setting the cruise control at 70kph/44mph it sometimes stays in fourth gear and around 1900rpm while on other occassions it will shift up to fifth gear and around 1400rpm.
Sometimes I need to adjust it (via cruise control) all the way up to around 82kph/51mph before it decides to shift up to fifth.
The oil was changed about 12K miles ago when the gearbox was taken apart due to a worn down clutch plate. The mileage at that time was only around 60K miles. The issue with the indecisive shifting was there before the transmission refurb as well.
Two questions in this regard:
1) Will a new software update fix this? Last time I had the car updated via service was about 2 years ago.
2) Will the indecisive shifting between 4th and 5th gear with cruise control on cause unnecessary wear on clutch plate?
Help is much appreciated!
Chris
Chris
