1 - 8 of 8 Posts
Hey guys so I was wondering if any of you have or know of any launch control and trans brake applications for the M66? For obvious reasons I want a better 60ft at the strip. If anyone knows of a launch controller that would be awesome too. 3k I'm guessing is our sweetspot
Nobody really launches the R because of the weak AWD components. (Angle gear and collar sleeve )
Yeah I need to replace my rear components and plan on getting a stronger angle gear and coller I found online
Sent from my VS880 using Tapatalk
GL finding a stronger angle gear--unless you're retrofitting a P3 one in you are pretty SOL.
Well if I don't find anything online I can always drive out to my uncle's shop and machine one, going to also make a crank position sensor bracket cuz I broke mine when I replaced my clutch and broke the replacement one haha
Hilton has the tune
Go for it as I will be watching and hope to get in on that angle gear
Bewbzout had a line on a p3 angle from australia that would bolt p to p2 cars.
1 - 8 of 8 Posts
