hi everyone new to site, not to volvos, used to own a 85 dl, and sold it and now am getting back in the game. so ive got a car lined up, 82 240 turbo, its automatic and would like standard. my question is there is a 85 dl non turbo with stand trans. can i bolt that up to my turbo motor in the 82? the 82 is carbd and im assuming the 85 is fi.<br>thanks for any help guys-tony<br>also ive got access to lifts and all tools needed for the job.
Re: Trans Swap Questions (rockndrifter06)
Welcome to Swedespeed, Tony.<p>Jusy a bit to hot in your part of Texas to be swapping transmissions!?<p>An '82 240 turbo with carb? Not from the factory unless such was available in Canada or Europe.<p>For an answer to engine/trans combinations visit<p><A HREF="http://billgarland.mcmaster.ca/volvo/volvohome.htm" TARGET="_blank">http://billgarland.mcmaster.ca/volvo/volvohome.htm</A><p>Good luck!<p>George Dill<p>Temple, Texas, USA.<p>
thanks for the site. lotsa confusing information! not to hot just get that swamp cooler on you while your working and its all good.
Re: (rockndrifter06)
Clink! Here's to confusion!<p>It goes like this...<p>From 1975 (late) through 1993 any 240 manual trans will go into any 240 model (except V6 and diesel).<p>As each engine model replaced the previous and each transmission model was fitted the connecting pieces changed as did the electronic stuff to run the control systems (late models).<p>So, with a little work you can fit any 240 manual trans into any 4-cylinder 240 regardless of engine (B21, B23, B230 etc.).<p>George Dill<p>
