Re: (kakalak)
It probably downshifts to allow you to regain your speed when the hill stops. Just a guess, I live in Houston... we don't know what hills are. http://********************/smile/emsmilep.gif
and No, It is not normal at all. The RPM's should adjust themselves when you take your foot off the gas, but not that much. Going 60mph at 1800-2000 RPM, when you let off the accelerator completely the RPM's should only drop somewhere around 100 per seccond, until you hit your brakes, which will cause the engine to slow faster.
Hope this helps. http://********************/smile/emthup.gif
