1 - 8 of 8 Posts
it happens when my car is first started up in the morning...
the car isnt temperature wise cold..it just hasnt been started in about 8-10 hours...
when i shift to reverse to move out of my driveway, i hear a rattling as if sumthing was shaking loose in my car, or sumthing is grinding.
the fluid of the trans is fine....oil is fine... and the problem doesnt exist after i have driven it around.
is this normal? or should i take it in and get it checked? warranty?
If you had special aftermarket flywheel, it would be that clinking around a bit, as they tend to do when no load is on them, but if you're stock, dunno.
I would check your engine mount not the one on top but the one on the right side. That might be broken..have them replace it with a stornger mount..
Re: (GShyneDM)
well.. all the mounts were checked, and the dealer said there was nothing wrong, said they couldnt repeat the problem.
*shrugs* i still hear it.. and it seems more evident than ever. grrr
oh well.. i got extra insurance warranty from AIS.. so i hope if anything happens in the future, its covered.
Re: (GShyneDM)
Do you have auto or manual?
Hmm....if you have a manual and the ticking continues and triggered some check engine light, you are in trouble. http://********************/smile/emdgust.gif
Re: (The_one_n_only)
automatic... it gets kinda rough from neutral to reverse shift change... its weird...and Volvo doesnt seem to want to hear the problem until i pay for it
1 - 8 of 8 Posts
